Peugeot and Cruise Control [ANKARA]
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 18:17 # 1
Alicilik
Hello friends,
I know I had the opportunity to work on many vehicles related to the subject, but there are still many ways to go.
Even if you do not have any doubt about the previous operations, there are no situations that will affect the vehicle or the driver in any way that will damage the vehicle. I activate the hardware and software on the vehicle.
Until now, I have been able to try many vehicles and I have achieved success in most of them.
Important ones
The vehicle is a 2003 model and above. From 2002 onwards, the pejo infrastructure moved completely from multiplex to van and life systems, so that the communication of the brains with each other would be easier and smoother in the vehicle.
Appropriateness of parameters in BSi and ECU. It may not support every ECU and BSi.
Gas pedal with potentiometer, namely signal. Wired mouth does not pedal
Brake and clutch detection contactors. The system known as Musur is in clutch and brake pedals.
If these happen, all that remains is to activate the system with the help program (pp2000-diagbox).
I serve in Ankara for these transactions. In high model vehicles, the process takes 20-25 minutes, while in old system vehicles such as 206 307, the process may take a little longer. I can not say that it will be certain in 206 and 307 vehicles.
Unfortunately, I do not have any work outside of Ankara. The only person I can recommend is Mehmet in Adana.
If we come to the tools I've been able to do so far, I will create a current list below.
You can reach me by posting this message on the forum, by posting a private message or from the link in my signature.
To communicate,
Ali Mikail ILHAN
537 380 32 86 (whatsapp & line & tango & viber)
I hizimsabit.co
fb.com/hizimsabit
receptivity 2014-11-14 00:30:33
08.05.2020 18:17 # 2
Alicilik
Peugeot
2004 206 1.4 HDi
2004 206sw 1.4 HDi
2004 307 1.4 HDi
2004 307 1.6 XS Gasoline & LPG
2004 307 1.6 Gas & LPG
2005 307 1.6 AL4 Gas & LPG
2005 307 1.4 HDi
2005 206 1.4 HDi
2007 206 1.4 HDi
2007 307sw 1.6 HDi
2008 308 1.6 HDi Auto6R
2009 206 sedan 1.4 Gas & LPG
2009 308 1.6 HDi
2009 308 1.6 HDi Auto6R
2009 Partner 1.6 HDi
2010 207 1.4 2Tronic Gasoline & LPG
2010 Partner 1.6 HDi
2010 308 1.6 HDi
2010 308sw 1.6 HDi
2010 308 1.6 HDi Auto6R
2010 206+ 1.4 HDi
2010 206+ 1.4 Gas & LPG
2010 308 1.6 HDi
2011 207 1.4 HDi
2011 206+ 1.4 HDi
2011 206+ 1.4 Gas & LPG
2012 206+ 1.4 HDi E5
2012 206+ 1.4 Gas & LPG
Citroen
2008 C3 1.6 BVA Gasoline & LPG
2009 C3 1.4 HDi
2010 C3 1.4 HDi
2011 C3 1.4 HDi
2012 Berlingo 1.6 HDi
receptivity 2015-04-23 16:59:36
08.05.2020 18:17 # 3
Serkan
Come on, good luck Ali, thanks to you, Peugeot will not remain without speed stabilization, I have given you the authority to edit for this episode. We are waiting for their work.
08.05.2020 18:17 # 4
good luck your page Ali :) I am getting a lot of prayer.
08.05.2020 18:17 # 5
gkhn08
I was wondering when you will clarify this issue and how it is done now :)
08.05.2020 18:17 # 6
newlook45
I'm waiting, brother
08.05.2020 18:17 # 7
Alicilik
Unttum is gone here: D
I worked a little at a leisure time: D
08.05.2020 18:17 # 8
reality59
Ali, especially I look forward to this topic :)
08.05.2020 18:17 # 9
Alicilik
[QUOTE = reality59] Ali, I am especially curious about this topic:) [/ QUOTE]
Haji you couldn't do it yet: D I will come and do it yourself now: D
I did not have time, I was very enthusiastic for a while and a lot of time has passed.
08.05.2020 18:17 # 10
reality59
[QUOTE = Buying] [QUOTE = reality59] Ali, I am especially curious about this topic:) [/ QUOTE]
No, I couldn't do it again :)
08.05.2020 18:17 # 11
Alicilik
A current ...
08.05.2020 18:17 # 12
ahmet_bjk
I recommend the cruise control to anyone who fits the vehicle
ahmet_bjk 2015-01-05 03:27:32
08.05.2020 18:17 # 13
ysndrsn19
2006 206 1.4 gasoline lpg automatic. I wonder if it does. What happens at the cost
08.05.2020 18:17 # 14
Alicilik
[QUOTE = ysndrsn19] 2006 206 1.4 petrol lpg automatic. I wonder if it does. What happens at the cost [/ QUOTE]
I can not say that 206 gasoline vehicles will be certain, 2004 and 2005 did not. You have to try.
08.05.2020 18:17 # 15
ysndrsn19
So let's say we haven't tried, what is the cost to us?
08.05.2020 18:17 # 16
Alicilik
You only have a travel expense
08.05.2020 18:17 # 17
emreeee
Let Ali come easy first, I am writing from Bursa, I have 2004 model 307, I have 1.4 hdi I mounted the arm, I searched, I found the master in the bursa, I found it good in 207s before, but I could not do it in the vehicle, CC off was written, the speed I went to was writing, but I did not come to the position. no limit, I wonder if it is possible from pp 2000 speed limit cikio said the master can you help me
08.05.2020 18:17 # 18
Alicilik
[QUOTE = emreeee] Ali first come easy, I am writing from bursa 2004 model 307 I have 1.4 hdi I mounted the arm, I searched, found the master in the bursa, found the master in the bursa before, in 207, he did this job, but I could not do it in the vehicle. I do not come, I do not have any limitation on the arm I installed, can you be from it?
If CC text appears on the screen, there is no job. Take back all the operations and enter on the Partner and open again.
08.05.2020 18:17 # 19
mehmethannn
Hello, I have 2004-307 xt. vehicle gasoline.
I think it would be in my vehicle.
can you write an average cost.
a little far from Ankara but sometimes our way is falling. then we can have it installed.
08.05.2020 18:17 # 20
sanctuary35
2006 1.6 hdi 307, where can I get it in Izmir?
Page : / 5
