Peugeot Airbag light
15.05.2022 01:06 # 1
bilal67
Hello everyone.
Last week out of the blue the airbag lights came on and the horn was not working. I went to the master and he said that the airbag wrapping will be changed. I said ok, changed it, fixed it, horn etc. Then, on the same day, the lights came on again, but there was no problem with my horn. My return has been corrected. It's been 2 days now, this time only the driver airbag light is on. It gets better every now and then. But there is no problem with my horn. The mileage indicator sometimes drops to 0, does it have anything to do with it, what should I do?
Thank you.
17.05.2022 10:52 # 2
If you remove the lower steering wheel, there is a brown socket, check it first, it may be loose. The other problem is that the indicator needle motor may be faulty.
