Peugeot 508 wiper and airbag problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 508
13.02.2022 16:56 # 1
zamazingo
Hello. We are facing a problem that started yesterday and still continues in my 2011 model 508 vehicle. While the vehicle was moving forward, the wipers started to work on their own and at the same time, airbag fault information appeared on the dial. The interesting thing is that even when we turn off the ignition, the wipers continue to work on their own. We have to remove the battery terminal after getting out of the vehicle.
I wanted to write it here in case someone had a similar issue before. I wonder if this situation is related to the engine brain, what is the solution, if someone who knows can enlighten us, we would be very pleased. thanks.
13.02.2022 17:26 # 2
SonerAK
Hi . I had a similar situation on the morning of a rainy night when my wipers were getting ridiculous. Our wiper motors break down because they are produced with cancer. Since the damn thing is made with 2 motors, you will have to replace 2 wiper motors, even if you change one. I also broke down, drooled and gave an aorbag error, I changed it, I gave 2.100 TL last year. Then I smashed the broken one of the old engine, it was rusty with water in it
13.02.2022 22:41 # 3
zamazingo
So the problem has nothing to do with the brain. So what master should I go to to fix this problem?
14.02.2022 11:17 # 4
As our soner friend said, sir, you encounter this problem because the wiper motors take water over time and become oxidized. A good Peugeot master will take care of it or a good auto electrician will solve your job.
14.02.2022 11:21 # 5
zamazingo
I took the car to an auto electrician today, BSI said it was a problem, that is, there seems to be a communication problem between the insurance of the vehicle and BSI. I will leave the car tomorrow, it will be clear what the problem is. Thanks for the comments.
14.02.2022 11:38 # 6
Well, sir, not everyone understands the peugeottu, let me tell you, I hope he is a good master and will not cost you anything.
14.02.2022 22:08 # 7
SonerAK
As my namesake said, don't touch the vehicle, 99% wiper motor, which I have heard is chronic, and the electronic event of our vehicles is a bit strange. I bought an android oem tape 2 years ago, 5-6 years later, the tape turned off and the engine was malfunctioning. They said the battery was changed, I changed the brain, then they said, I didn't like it, research it, tamper with it, etc. The last tape was made from canbus flour, I went and bought a new one for 200 TL, the problem was solved, otherwise we were losing 5-6 thousand.
17.02.2022 13:52 # 8
zamazingo
Problem aracın sigorta kutusunda çıktı. yani ustanın dediğine göre, sigorta kutusu ile BSİ arasında iletişim problemi olduğundan sorun meydana geliyormuş. Sigorta kutusunun değişmesi lazım dedi, çıkma bakıyoruz şimdi. BSI ise iyi durumda dedi.
Bu arada sigorta kutusu zaten problemliydi. oksit problemi vardı, temizlettik falan ama tam randımanlı çalışmıyordu. Sanırım zaten bu parçanın değişmesi gerekiyordu. Ancak anlamamadığın şey şu oldu; usta telefonda araç yanlış kodlanmış dedi, düzelteceğiz falan dedi. yanlış kodlama ne demek açıkçası çok anlamadım.
31.12.2024 22:29 # 9
Abidin
P.S. I have the same problem. How did you solve it?
