Peugeot 508 Steering Wheel Radio Control Problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 508
08.05.2020 15:45 # 1
MrFly
Hello everyone,
I am not sure that I opened the subject in the right place. I have been using Peugeot 508 active 1.6 e-hdi auto 6r for 1 month. and I became a new member of the forum.
I have a classic radio cd player in 508, I cannot navigate through the radio channels stored on the steering wheel. I can only navigate between frequencies from the spinner on the right. unfortunately I couldn't figure out whatever I did.
If you have any information, I would like you to share it.
If you have questions about the vehicle, I try to answer as much as I can, I've already traveled 4450 km and an average of 6.0lt in vehicle fuel consumption.
08.05.2020 15:45 # 2
Our members who have completed their new membership and entered the forum, please introduce yourself by opening a new topic under the heading "Let's Know Our Members ". Filling in all the information will help us to know you better.
1.- Your name and surname:
2.- Your age:
3.- Your vehicle (Brand, model):
4.- Your hobbies:
5.- Your profession:
6.- Where did you hear the site:
7.- Your Blood Group:
8.- Your horoscope:
9.- The team you support:
10.- Which county or province are you in:
11.- Your MSN address:
Thank you for your attention.
Peugeot Turkey Fun Club Management
Www.peugeotturkey.co & www.peugeotturkiye.co I
08.05.2020 15:45 # 3
hallowman2005
Try pressing lightly on the rotating button on the steering wheel, a click should sound
08.05.2020 15:45 # 4
There should be a detailed explanation in the user manual of your vehicle. If not, let me explain as follows.
1) Peak cd-radio transition ..
2) Sides frequency search ..
3) Turning on the cylinder stored radio frequencies in the middle ..
08.05.2020 15:45 # 5
MrFly
Thank you very much for the information you provide. No such detail is mentioned in the vehicle's manual.
he says that you can only navigate between frequencies from the spinning button on the steering wheel.
Are the settings you mentioned valid for 508? neither there is such an arm, nor any reaction when the button is pressed
08.05.2020 15:45 # 6
very interesting .... can you type the county in the location of your brother profile .. friends close to you can help ..
08.05.2020 15:45 # 7
MrFly
I added now, sorry, please
08.05.2020 15:45 # 8
[QUOTE = MrFly] I added now, sorry, please [/ QUOTE]
+ 999 Thumbs Up
08.05.2020 15:45 # 9
MrFly
The problem I am having is really interesting, I think it should be certain to be able to navigate between the channels registered at 508, I would not find another 508 owner, if I find I will stop and ask
08.05.2020 15:45 # 10
[QUOTE = MrFly] The problem I'm having is really interesting, I think it should be certain to be able to navigate between the channels registered at 508 at the steering wheel, if I find another 508 owner, I'll stop on the road and ask it [/ QUOTE]
There is definitely such a feature of a vehicle in this segment. The most definitive way is to go to the dealer and explain the situation. Although the problem seems to be unimportant, whether this feature is working or not shows that the system running this feature is broken, leading to bigger, important problems in the future. stabilizer key not working etc.
No need to worry, I recently saw a broken 508 parking sensor. There may be such minor flaws, always a man-made machine after all ..
08.05.2020 15:45 # 11
hallowman2005
Source: 508 User Guide
hallowman2005 2011-07-05 14:55:50
08.05.2020 15:45 # 12
MrFly
Sec. Thank you very much Hallowman for detailed information, but unfortunately it does not function as described in the picture, it can only navigate between frequencies. I couldn't find a setting about switching between the two options in the settings menu. It has the setting of this function in the navigation tape in the user manual and it shows that it works exactly as described in the picture, but it does not mention the same function in the classical tape.
Maybe Mr. As Laedri said, there may be a malfunction, as soon as possible to go to the service and consult is left.
08.05.2020 15:45 # 13
Maybe you will be angry with me, but the car is new, you may not have recorded the radio? Came to mind. Otherwise, the feature you mentioned is even in bad 2006 clio.
08.05.2020 15:45 # 14
MrFly
Sec. Menderes getting angry is everything that comes to mind to help me in this troubled situation, I have saved all of them are already changing from buttons 1-6 on the radio right now
08.05.2020 15:45 # 15
hallowman2005
When I last review the guide again, Umut Bey has different information about the button configuration of the navigation system and the auto radio and the frequency change you have said is written in the section of the model with navigation. The first pictures I sent were the classic auto radio steering wheel control page, now I am sending the steering wheel control model. And this is completely my assumption; Almost the same BSI infrastructure is used in the same models and serials of our vehicles, and I think you have a classic auto radio in my car, could there be a wrong brain configuration?
hallowman2005 2011-07-05 18:28:44
08.05.2020 15:45 # 16
MrFly
Omer Bey went to the car quickly after reading, but unfortunately it did not work by pressing. Thank you very much, and I think that there is a problem in the radio or controls of the car. I do not want to believe that there is no such feature, after all, my active vehicle, which is a medium-full model of the vehicle
08.05.2020 15:45 # 17
I suggest you show it to the service, something that will cover the warranty, because this.
08.05.2020 15:45 # 18
hallowman2005
[QUOTE = MrFly] Ömer Bey went to the car quickly after reading, but unfortunately it did not work by pressing. Thank you very much, and I think that there is a problem in the radio or controls of the car. I do not want to believe that there is no such feature, after all, my "active" vehicle, which is the medium-full model of the vehicle [/ QUOTE]
I thank you . There is no problem to be in trouble, if you send your complaint to the dealer or authorized service where you bought your vehicle, they will definitely help you under the warranty.
