Peugeot 5008 2011 1.6ehdi semi automatic fault
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 5008
16.05.2020 16:08 # 1
Ali gbk
Right friends. I see that a friend of mine had the same problem in 2019, but my solution is not written, my problem is not: the car does not shift, "n" comes out, does not go forward or back. It was like the first time I removed the battery. But yesterday morning the car ran and the p1755 error came out. Whatever I did, I couldn't shift gears. I did tests with Diagbox again. As if the sensor on the pressure ball is faulty, my car is at 208,000km and kisses will start the pad + flywheel + pressure, so the problem goes away. When the reference position is closed, it should say that it should stop at 5.71mm, but it looks as if a clutch is attached. By the way, I am abroad so my turkish beer is weak :)
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
