Peugeot 407 rear trim fluid leak on right side |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 407 | |
| 08.05.2020 19:59 | # 1 |
I have a question I want to ask you. When I lifted the car's floor mats last night, I saw that the upholstery was cut and I noticed that the upholstery was wet. I'm going to take your pictures today. A pipe is kicking in the place I mentioned and the connection part of the pipe is quite rusty. I was down on my mood, seriously. By the way, it's not gasoline, because it doesn't smell. If there are friends with knowledge, I would be glad if they help.
| 08.05.2020 19:59 | # 2 |
sonerkyl |
firstly welcome. you call me the driver at my place
| 08.05.2020 19:59 | # 3 |
Check the trunk for a damp or wet area.
| 08.05.2020 19:59 | # 4 |
| 08.05.2020 19:59 | # 5 |
Thank you, the place I am talking about is under the feet of the right passenger at the back. Actually the flooring should be all, I looked at my friend's car so it is. I don't know why, but both sides are cut, and as you can see in the pictures, the sponges appear when you lift your upholstery and that part is damp and the pipe in the picture is rusty.
| 08.05.2020 19:59 | # 6 |
[QUOTE = xmen] Check the luggage section for a damp or wet area .. [/ QUOTE] Where can I check the baqaj section? the baggage looks clean I did not find anything unusual.
| 08.05.2020 19:59 | # 7 |
[QUOTE = plummedia] [QUOTE = xmen] Check in the luggage compartment for a damp or wet area .. [/ QUOTE] Where can I check the baqaj section? the baggage looks clean I did not find anything unusual. [/ QUOTE] In my 307 car, the water entering by the left headlight was entering the right rear passenger area directly. You can control the surroundings of the headlights by pouring water. And there was a cut in that part of my vehicle. Probably the owner or owners may have previously cut out to drain the incoming water ... |
| 08.05.2020 19:59 | # 8 |
[QUOTE = xmen] [QUOTE = plummedia] [QUOTE = xmen] Check in the luggage compartment for a damp or wet area .. [/ QUOTE] Where can I check the baqaj section? the baggage looks clean I did not find anything unusual. [/ QUOTE] In my 307 car, the water entering by the left headlight was entering the right rear passenger area directly. You can control the surroundings of the headlights by pouring water. And there was a cut in that part of my vehicle. Probably earlier the owner or owners may have cut off to drain the incoming water ... [/ QUOTE] Thank you. I'll see you tomorrow. Let's see what else will happen to us :))
| 08.05.2020 19:59 | # 9 |
[QUOTE = plummedia] [QUOTE = xmen] [QUOTE = plummedia] [QUOTE = xmen] Check in the luggage compartment for a damp or wet area .. [/ QUOTE] Where can I check the baqaj section? the baggage looks clean I did not find anything unusual. [/ QUOTE] In my 307 car, the water entering by the left headlight was entering the right rear passenger area directly. You can control the surroundings of the headlights by pouring water. And there was a cut in that part of my vehicle. Probably earlier the owner or owners may have cut off to drain the incoming water ... [/ QUOTE] Thank you. I'll see you tomorrow. Let's see what else will happen to us :)) [/ QUOTE] I checked the boot, I couldn't find anything, the trunk was dry. But I did not understand the tail light part. Is there a water pipe that goes around the headlights under the car? So this is because it is stuffy. Also, the pipe that appears in the picture comes from under the driver's seat.
| 08.05.2020 19:59 | # 10 |
My teacher can also enter from under the back door, by Sofor, the soner brain, if there is a leak in the heater core, it can flow into the vehicle. So there are many places where water can enter. Or, as you said, there may be a leak from that pipe. I hope you will solve the problem as soon as possible ..
| 08.05.2020 19:59 | # 11 |
[QUOTE = xmen] My teacher can also enter under the back door, soner brain can flow into the vehicle if there is a leakage in the heater core by Sofor. So there are many places where water can enter. Or, as you said, there may be a leak from that pipe. I hope you will solve the problem as soon as possible .. [/ QUOTE] I hope I will take you to the master this weekend.
