Peugeot 407 RADIATOR FAN WORKING WITHOUT STOP PROBLEM
04.03.2022 12:09 # 1
Marasliede
Unfortunately, I had an accident with his vehicle last month. They said they will change the hood and muddy. I agreed, the hood was muddy and the relevant parts were painted. But when I take delivery of the vehicle, as soon as the key contact is inserted, the fan is running strongly. I took the car for service again. In the electrical evenings, the mules checked the fuse and everything we could think of, but the balance of the fan in this way could not stop it from working. They're looking at the car's brain right now. I think that the vehicle did not leave its place to poke around. Dear friends, do you have any advice about this problem? good wishes
04.03.2022 17:52 # 2
First of all, congratulations, sir. Have you checked the fan resistance and heat exchanger cables thoroughly? There may also be a problem with the fan relay.
07.03.2022 00:04 # 3
Marasliede
Yes, you said, the parts were completely checked, at the end of the job, the engine brain was changed and the problem was solved. Frankly, I did not understand, there was no problem with the engine brain. There is a saying around here that you have a father around your neck. To the neck of the fathered service. But my problem is solved even if it is 5 thousand TL. From insurance.
07.03.2022 11:34 # 4
good luck, it looks to me like they had a short circuit. well, we leave the car to the service, another part of it breaks down without skipping the day.
