Peugeot 407 - In-car Camera + Navigation Link
Homepage » PEUGEOT MODIFIED PLATFORM » General
08.05.2020 19:07 # 1
OkanTekin
Hello friends ... We have already inherited the Peugeot 407, which we bought 2 weeks ago, from our old car (which was also a 407. I respect that friend too) We will connect our in-car camera and navigation device. - One navigation device3- A pinch of single-core cable4- Yankeski 5- Electric band6- Vehicle instruction manual7- A solder wire and soldering iron that can reach the consistency of the earlobe, even pushing the boundaries and even melting 8- The water meter 8- Hard plastic rod (for laying cables) 10- Oil water flour salt sugar black pepper11- A sip of love12- A few good guysI think that if we provide our materials completely, it will be beneficial for ourselves and public safety. Then let's knock on the door of the nation and say, "Brother, is there any of this?" Let's not disturb people ... Let me remind, by the way. The name of the car is "camel", the name of the navigation device is "Cevriye", the name of the camera is the camera. I didn't put a name on the camera. There is no voice, because .. There is a woman in the navigation talking or something ... I said, Let your name be Cevriye. It gets more enjoyable;) ----------------------------- Reminder: Keep the vehicle ignition off while you work. As a security measure. However, keep in mind that if the doors are not locked, the vehicle enters energy saving mode after 20 minutes and cuts the current everywhere. Keep it in mind. Do not think that the camera or navigation device is not working. Start the car, you can work for 20 minutes more so ... (407 also has a precaution to prevent the battery from running out. I don't know the other tools ...) First of all, both the camera and the navigation have such an apparatus. It hangs on the lighter part. It takes its energy needs from here. However, I intend to get it from the fuse box. Because I don't like cable tangs that run from the center of the console to the ceiling. There is a bad image ... A reminder; We thought to cut the cable of this adapter (ie, cut off the end part) and connect it directly to the fuse box, but there was a glass fuse in the end part (that is in the shape of a small cylinder). We said that this should remain a security measure and soldered the metal parts by soldering wires ... We have all the information about the fuse panel in our vehicle booklet. Here we find a fuse that we can buy 12V that we need ... As a result of our measurements, we decided to use the F22 fuse. This fuse gives 12V when the ignition is on and cuts the current when it is closed. It is exactly as we want it ... We loved it ... You see it. The yellow fuse inscribes F22 underneath it ... 20A in one ... We will pull the cable there later ... There is a piece between the driver's door and the console in order to carry the cables comfortably and pass it behind the console. We need to remove this piece. We will both pass the cable and connect the current we receive from the fuse to the chassis for the camera and navigation we will use. So grounding ... That is the part that we're going to pull a cable to our fuse now. Yellow cables + tip, purple cables are used as ground / chassis. Keep in mind ... We also do our grounding ... In the meantime, after connecting the cable to the chassis, you can apply hot silicon on it. It becomes more solid. Of course you know ... Actually, there should be another photo here. Let me tell you. You connect the purple cable to the staple like the clamping latch next to the cigarette lighter socket. You attach the yellow cable to the far end of that lighter. The event is ending ... As long as the contact is open, 12V 20A current will pass through our cables. This is enough to operate the camera and navigation device .... That's all ... If anything you want to ask, I try to help as much as I can. Or if you say you can take a photo of this part, I can go to the car and take a photo .... Goodbye ...
08.05.2020 19:07 # 2
trabzonlu207
Why do people need an in-car camera
08.05.2020 19:07 # 3
OkanTekin
Because we are idiots, we need such nonsensical things. Are you alias, beautiful brother;)
08.05.2020 19:07 # 4
trabzonlu207
[QUOTE = OkanTekin] Because we are idiots, we need such nonsensical things. Would you be alive, my beautiful brother;) [/ QUOTE] what kind of answer style is this ??? Is it a shame not to know what it is doing ???
08.05.2020 19:07 # 5
trabzonlu207
You first learn to answer respect for the person in front of you. No need for Intelligence to answer like a man !! You give me
08.05.2020 19:07 # 6
OkanTekin
I insult us, not you, why are you being taken over?
Look, I have done so much research that I waited 1.5 months for that camera to come from China. I went and assembled in the middle of the night, I took a picture so that someone else could benefit from this in the forum ... I made a narrative ... Then, if someone came to me and said, "What is this for? Did I tell you, my beautiful brother?
If you do not want to get such an answer, ask your questions properly, I am not a rude person, of course I will answer properly ... Otherwise, it is very natural to encounter such an answer ... the okantek 2015-02-22 11:32:52
08.05.2020 19:07 # 7
trabzonlu207
[QUOTE = OkanTekin] I'm not insulting you, why are you being taken on?
If you do not want to get such an answer, ask your questions properly, I'm not a rude person, of course, I'll respond properly ... Otherwise, it is natural to encounter such an answer ... [/ QUOTE] what is yariyo la bu ?? Only one can use it. Since I am a lady, I kindly ask the in-car camera Why is it necessary? I understand my cable without grounding from the fuse, my beautiful brother ... Of course, this is working .. My head. If I go to bed, I will go there .. Maybe I have not seen before .. My first car .. !!
08.05.2020 19:07 # 8
OkanTekin
It does not mean that you are a woman for me. Everyone is equally in my eyes. Let me say it well then. It is easier to prove your right in case of a possible accident thanks to these cameras. For example, you can use it as evidence against a man who says "he passed on the red light and hit me" even though you did not pass on the red light (it happens to the woman). It is an arbitrary need. It is compulsory in Russia. I hope it will be mandatory in our country too ... Regards beautiful brother ...
08.05.2020 19:07 # 9
trabzonlu207
[QUOTE = OkanTekin] It does not mean that you are a woman for me. Everyone is equally in my eyes. Let me say it well then. It is easier to prove your right in case of a possible accident thanks to these cameras. For example, you can use it as evidence against a man who says "he passed on the red light and hit me" even though you did not pass on the red light (it happens to the woman). It is an arbitrary need. It is compulsory in Russia. I hope it will be mandatory in our country too ... Regards beautiful brother ... [/ QUOTE] thank you for your explanation!
08.05.2020 19:07 # 10
OkanTekin
You're welcome !
08.05.2020 19:07 # 11
Efe-Pojo
If this is mandatory in our country, I think the folks use it to record scissors video, so I think it will increase the accident more.
08.05.2020 19:07 # 12
GokhaN
There is no need for any unnecessary discussion. Health has been a very good sharing. Wink
08.05.2020 19:07 # 13
KuzuX
Good health to your hands. I use gopro when I want to record videos inside or outside the car, not on accident situations, but on long trips. Mine is not needed, of course arbitrary :)
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
