Peugeot 407 2.0 executive lpg
08.05.2020 17:08 # 1
sedatguler40
Hello everybody, peugeot and & nbsp; I just joined your forum world & nbsp;.
I will have both my experiences and questions in my first message with your permit.
I bought the 2006 model 2.0 executive car. I took care of the brake sensor change & nbsp; and the speed stabilizer fault warning was all interrupted because of this reason. It started after 150 km but its intensity was the same. 4. He saw 150 km in gear, then he made a lot of noise after that, we left it at 180 km in 5th gear because the road was the only road.This performance satisfies me. I am not going to get there anyway. There is no service on the ground. > and the car trembles when making a sharp turn in first gear (new tires have dropped significantly but still a little.)
& nbsp;
has been a bit long, sorry, thank you everyone .
08.05.2020 17:08 # 2
impact
Welcome, I wish you could use it without any trouble.
I had the same problem about LPG. We used it for about 2 years. I do not remember, but I think there was a problem with the spraying sequence of the injectors.
08.05.2020 17:08 # 3
bahcekapili
Don't be too stuck with this tremor. We are as stiff as the steering box of French vehicles and I have not seen a problematic system yet. No matter how many Citroen, Peugeot I have used, they are all the same. You know no more than 1 to 2 years based in Turkey road. Then the gap begins, and then the setting does not hold. Do not get any repair or repair, it will occur again after 6 months. It is very likely that the source of the tremor that occurred to you is from the steering box. The same problem exists in my 2.0 Citroen C5. The same happens after 2 years, if you buy a zero steering box and take it (around 2.000 TL).
