Peugeot 406 traction and idling problem |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406 | |
| 23.06.2020 19:22 | # 1 |
| 24.06.2020 13:26 | # 2 |
I also have a problem of idling. I changed the idle motor, it was a bit good, but generally, this problem occurs in 406s with LPG. But according to your expression, the idle fluctuation in gasoline may be due to the coil. You should consult a trusted master have the coil tested. And there is still a retraction problem that I could not solve, I guess it has nothing to do with the transmission. I do not change the coil due to the coil, but my master told me that I should change it. If you solve your problem with withdrawal, I would be glad to share it here. Off Topics I'm from Adana, I live in Istanbul :)
| 24.06.2020 13:27 | # 3 |
I also wondered what the cost of 10,000 was
| 24.06.2020 15:54 | # 4 |
Hello again, all the filters of the car were changed, the solenoid valve was the sensor, the transmission oil was changed, we trusted the master when the car was taken, and we did not know that the engine and gearbox oil leaks and the undercarriage were completely exhausted because the man was not looking at the lift. Changed up to the rear crank seal. Engine oil changed 3 times. When the last car was on the road 3 times, we had to change a zero gearbox for 4500 TL. Recently, we changed all sub-sets and pads. The timing and 4 more tires will change, plus there are the problems I mentioned above. Unfortunately, the former owners of the car did not look at anything. When you look at it from the outside, hey mashallah look at the majesty, but here's the inside burned me. Let me look at this ignition coil and write it here. Greetings from Adana.
| 25.06.2020 02:07 | # 5 |
Aleyküm Hi :) Well, well, well, if all your problems are solved, you will be relieved. 406s are not models that cause problems all the time.
| 08.07.2020 19:19 | # 6 |
I wonder if anyone has any other information on the subject?
