Peugeot 406 SV V6 3.0 LT withdrawal problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 16:41 # 1
erman1234
Hello. Firstly, my car is a 1998 Peugeot 406 SV V6 3.0 liter automatic. In the morning, I start my car and start driving, as I have no problem in the first place, when it gives some gas to the car, it goes very well in 1st gear, but when it shifts into 2nd gear, a certain 2000-3000 rpm car pretends as if it is drowning. The engine of the vehicle is hotly reduced, no matter what gear it is in. Sometimes it gives beautiful performance, sometimes it doesn't. I do not understand there is an irregular performance situation. When the vehicle stops driving at traffic lights, sometimes when I park the car, if the mosque is open, there will be a wake-up sound similar to the expansion sound. I changed the newer oxygen sensor and potentiometer of my vehicle, the oil was renewed. I want to add a presentation. I do it myself a little bit with this tool, I changed spark plugs myself etc. I do not know why I put the manifold, when I attach the manifold of the vehicle etc. the vehicle performs very well for a certain period of time, but there is no continuity. I experience the same performance problem again after a certain time.
08.05.2020 16:41 # 2
Good morning:
Our new members should first visit,
http://forum.peugeotturkey.com/forum_posts.asp?TID=7516&title=new-yenin-denkatine-konu-amadan- Please read Reviews
08.05.2020 16:41 # 3
erman1234
I'm sorry. I found the site via google and I entered the subject directly to find the solution to my problem as quickly as possible. Thank you for your warning.
08.05.2020 16:41 # 4
erman1234
There are a few things that I forgot to mention, after the room has shifted from 1st gear to 2nd gear, after 2000 3000 performance, the car does not perform as easily as I started first and move, so the engine sounds as if the engine is hot, as if it did not perform smoothly 5 the cylinder sounds like it's running.
erman1234 2012-04-03 09:36:10
