peugeot 406 oil pressure insufficient
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 16:32 # 1
HuSeNN
Hello friends,
& nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; Yesterday evening at 19:00 I went to the antarch, I came to the front of the house like 20:20, parked the car, got out of the car (there was no problem until here.) Then I went to the car again, the ignition was turned on, the oil lamp was on + the stop lamp started flashing and gave a warning sound. dııttttt. This screen is also displayed on the computer screen (my oil pressure insufficient) 406 2.0 engine.
How could I fix this failure? . "Cry" "Cry" "Cry"
08.05.2020 16:32 # 2
yavuz25
There may be a problem with the filter in the pump. Show it to a master without starting the tool.
08.05.2020 16:32 # 3
06OzGuR06
[QUOTE = yavuz25] pump may have a problem with the filter. Show it to a master without starting the tool. [/ QUOTE]
Exactly. Do not neglect if the filter maintenance has come. Also use the filters originally & nbsp; Using sub-industry is always risky. "Wink"
08.05.2020 16:32 # 4
HuSeNN
Thank you tomorrow I will take it to the master with the savior. I hope there is a problem in the places you say and it gets better & nbsp; :)))
08.05.2020 16:32 # 5
djchaos
Do not forget to avoid the external parts of the original parts, do not be 5 cents by calculating 3 cents and do not forget to have your car connected to the computer.
08.05.2020 16:32 # 6
HuSeNN
The battery was dismantled (oil pressure insufficient), the problem has improved but now another problem has occurred. I took the car to the master with the rescuer today, the gas was not coming to the car, so it was not working, the master changed the gas pump and fixed it. It showed the same speed, it went down to zero, the yellow light started flashing, I went to buy 50tl gasoline, nothing changed, we got zero buoys, he did the same: I wonder why this problem might be due to it. When I open it, the pointer quickly shows full and immediately falls back: S offffffffff offfffffffffff & nbsp; Reviews
08.05.2020 16:32 # 7
06OzGuR06
[QUOTE = HuSeNN] Battery disassembled (oil pressure insufficient) The problem has improved but now another problem has occurred. Today I took it to the master with the rescuer, there was no gas coming to the car, so it was not working, the master changed the gas pump and fixed it. the gasoline pointer quickly showed full, it went down to zero at the same speed, the yellow light started flashing, I went, I bought 50tl gasoline, nothing changed, we got zero buoys, he did the same: I wonder why this problem may be caused by the reason. But now when I turn on each contact, the pointer quickly shows full and immediately falls back: S offffffffff offfffffffffff & nbsp;
& nbsp; Disconnection or lack of contact after parts replacement & nbsp;
If you want to show it to an auto electrician again, you can connect the car to the computer and delete the registered malfunction codes
. "title =" Smile "/>
06ÖZGüR06 2012-01-21 02:39:27
