peugeot 406 HELP
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 15:04 # 1
fastboy_67
slm friends please help me. i became a new member in the forum I have a 2000 model peugeot 406 st 2.0 vehicle.It has gasoline / lpg at 190 thousand km. have the same problem. Could it be from injectors? The malfunction lamp is not lit at all. There is no problem when I am in the gas that confuses my head. Did I switch to gasoline, the vehicle stops and idle wheezing while idling. what else can happen I'm waiting for your help
08.05.2020 15:04 # 2
Eyup Duygun
According to the support of the injector, this complete system comes into play. Gas pump-fuel paths etc. are very difficult to diagnose from here. your vehicle.
08.05.2020 15:04 # 3
fastboy_67
The reason I suspect the injectors is not to do the same thing in the gas. Isn't the only difference between gas and gasoline is that the gas injectors are different, everything else does not continue in the same way? Bide, a master said to me that he could be breathe air, could it be a problem if he got air?
08.05.2020 15:04 # 4
tugrabozan
He had me from the same vehicle. Generally, there is no problem when the vehicle is in motion, but if the idle needle shakes and stops occasionally while it stops in the red light when it is wasted, the idle stepper motor is probably contaminated. I don't have the pictures at the moment, but my problem was solved when he removed the engine and got a sheath like body from tip to body.
08.05.2020 15:04 # 5
fastboy_67
If my friend has the pictures, can you send it to me, please, I would be happy if you help me. fastboy_67 2011-02-04 23:08:07
08.05.2020 15:04 # 6
tugrabozan
I could not find the pictures, because I sell the vehicle, I cannot take a new picture Ouch the engine that I call just under the throttle. you can remove it with tors allen. Less hormone of 7-8 cm long tape motor Sırıtma
08.05.2020 15:04 # 7
fastboy_67
I think the diode on this intake manifold is the sensor
08.05.2020 15:04 # 8
06K1387
FRIENDS HAVE BEEN A NEW MEMBER AND 406 USERS. I HAVE THE SAME PROBLEM IN MY VEHICLE, BUT MY GAS IS NOT SIMILARALLY GAS OR MAKES THIS PROBLEM. I WOULD LIKE TO ADD THE PICTURES YOU HAVE TAKEN FROM ANY OTHER VEHICLE. I WILL TRY TO PUBLISH THE PICTURE OF THE MOTOR OF ITS OWN VEHICLE. YOU CAN USE THESE PICTURES. THANK YOU FROM NOW.
