Peugeot 406 D8 Water Auction Problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
14.06.2020 18:14 # 1
burakipek34
Hello friends, 1999 D8 2.0 Gasoline + LPG My problem started like this in my 302xxx and then I continue to thank you for your solution and suggestions. We added antifreeze a few months later, and the radiator lower hose broke out after 2 days during maintenance, we completely changed. I think it is called thermostat billet, there was a leak there, we changed the gasket and thermostat, we cut the problem. A few weeks later, while I was cruising, the hose to the LPG regulator exploded, I realized that the water was giving off smoke, I pulled aside, after waiting for a while, I went to the master who was about 1.5 km away and turned off the regulator's hose, turned off the LPG system and connected it directly, I went to the LPG service and the regulator and hose changed. . Despite all this, my vehicle is still losing water. I changed the radiator cap, it continues, I was desperate ... There is no case of water mixing with the oil, I will show it to another master on Wednesday ...
15.06.2020 15:50 # 2
Hello, is the reserve water tank intact, my teacher, I had that problem in my current vehicle. coincidence was coming out of a small crack when the pressure was high. If your backup water tank is old, replace it with a new one.
16.06.2020 14:13 # 3
burakipek34
spare warehouse intact today I showed turan master gasket says get well soon ....
16.06.2020 14:30 # 4
Let's get well soon, teacher.
16.06.2020 16:04 # 5
burakipek34
Thanks insin, there will be no problem in the upper cover, if it does, we will be smoke :(
16.06.2020 16:57 # 6
I hope there will be no problems with the valves, otherwise it will be very costly.
17.06.2020 01:51 # 7
burakipek34
I hope there will not be such a big problem, if it does, I think to sell it that way. It will not be a logical move to have a lot of difficulty in terms of material these days because ..
23.06.2020 03:12 # 8
burakipek34
Friends, let me share the last update.After the first messages I wrote, we added a powder substance, 100km since the day we put it in the spare water tank, there has been no water loss, the values seem normal, but it seems like a temporary solution.
