Peugeot 406 Coupe-Indicator Problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 16:26 # 1
selenge
Let me talk about my friends problem briefly, I disassembled km meter, I changed the light bulbs, I changed the bulbs ... Then I came to my mind, I thought, it was not difficult to guess after it. when I insert it, for example, when I turn the key to turn the tachometer lever on it, it bounces a little bit. Normally the car is 90 dions when it is at 2 thousand rpm, now the tachometer shows 90 at 3 rpm, I am not sure even the speed is correct. I have put the hands in place, there is a method for adjusting the buttons ... I have done something, for example, I have brought the hour hand to 50, then put it counterclockwise around it and then leaned it on the piece of rubber that held the lower hand. ... but what exactly is the right water under it .... n has a rotating magnetic mechanism, attaching the needle and moving around & nbsp; the more turns you run in the opposite direction, the more strands in it come to the tensioner, for example, I had almost 90 speeds in my experiment but the needle showed 10 dislocated ... do you have a standard of it ... how can i fix it :)) it was long but per head It is not a topic that I hope you will understand, but, I think maybe friends whose mind is the same as me, to break the car, confuse your left, can help me .. & nbsp;
08.05.2020 16:26 # 2
selenge
Guys, does not anyone know about this? My dashboard is broken, guys, how do I set up ...
08.05.2020 16:26 # 3
06OzGuR06
It seems to me that the km indicator is quite confused from what you tell me. I don't know if there is anyone trying this, but I think that if there are any, try to find an indication clock and adjust it by looking at it. Maybe it works. Easy to come.
08.05.2020 16:26 # 4
mehmetaydinpug
I wish I wish you had never been tampered with it, it is not like tofaş, I say halal for your courage but you are inconclusive.
08.05.2020 16:26 # 5
yavuz25
You have played with a very sensitive piece.It may be the cause of malfunction even if you disassemble it.The hands are the most sensitive places. I would.
08.05.2020 16:26 # 6
selenge
[QUOTE = mehmetaydinpug] I wish you had never been tampered with it, it is not like tofaş, I say halal for your courage but you are inconclusive. , I am in Kahramanmaraş .. do we have the possibility to get it out and send it .. can you help me ..
08.05.2020 16:26 # 7
I think, get on the vehicle, remove the indicator hands, start the car and take a turn, then stop, all the hands will already show zero adjustment, ie handles. then put the hands on those arms so that they all point to zero. & nbsp; Straight Logic & nbsp; :)
08.05.2020 16:26 # 8
yavuz25
[QUOTE = xSOLOx] I think, take off the indicator hands of the vehicle, start the car and take a turn, then stop all the hands will already show zero adjustment, ie handles. Then put the hands on those arms so that all the hands are zero. If it plays a little more, I think there will be no indicator to repair. "
