Peugeot 406 Authorized Service LPG problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 21:14 # 1
Lsuersoy
Hello Friends,
Peugeot 406 2000 SV OTO.Vites Trafige was released in 2000.
I bought it in December 2012.
Normal costs to bear:
I made summer and winter maintenance. 2 times a year, (Engine oil, filters, lining, Brake, Hydraulics, Transmission oils) Passed the inspections
LPG Maintenance regularly and guaranteed for 6 years in KARTAL Auto Industry. >
But especially in the last 2 years, the vehicle has been very costly. Heater core was replaced with Original. No Heating and Cooling problem. The glasses do not steam in the winter.
Extra fantasy costs I endure. I painted the car in its original color. Pasta-Cila 4.000 TL
I replaced the headlights with Originals. 1500 TL
But now also the door locks have failed, the driver's side was already problematic. When I bought it from time to time, so we were handling it from the front left passenger door, now it also failed.
The knuckle was malfunctioning, I had it repaired. In the last 3 weeks, something like this happened to me. I parked the car, closed the doors from the button with the key, but in the morning I called the Locksmith, where the doors did not open.
Because the authorized services do not look at the Peugeot LPG.
My vehicle has a Helmet. Do I have a chance to change these locks to private peugeot services within the scope of automobile insurance? Is it possible to ensure that at least 1 lock is replaced, at least around 560 TL of locks?
The walker of my vehicle is solid, engine bottom flow ear (Gasket 40 TL, labor 150 TL) will be replaced The problem will be eliminated when the ear changes slightly.
Also, the TOP Display in the Radio-Tape section does not work, you cannot see the Date Time and temperature. You can not see the radio frequency, but you can see the DOORS open state, I think there may be a cold SOLDER problem ... Or the Cristal screen may be defective, but since they want 400 TL of workmanship, I have never searched for the part and frankly I don't need it.
no.
How many TL should I ask my car for?
The condition of the upholstery is not nice, there is a fabric cigarette response 1 piece I burned. There are also disassemblies in the door handles section.
Costs to be Incurred by the Receivable Person:
1 - Laying should be done: There is a cost between 400-5000 TL for pleasure. After 2 - 20,000 KM, the Trigger belt set will need to be replaced. It can hold 500 TL or more. 3 - In the ceiling, I did not paint the ceiling because I used Port Luggage, if you want to paint it, it will cost 400-500 TL. 4 - I do not know in which mechanic he forgot, but I do not know what the cost of the pollen filter is missing, its filter is necessary to prevent the filter from clogging up the scarab beetles and leaves. 5 - Luckily, there is no big problem, the gears are normal but sometimes when you want to slow down the speed and accelerate from one point, that is, if you override the throttle, it can be knocked in the gear shift, this is actually a situation arising from the ear of the engine, it will disappear when it is changed. The Solenoid Valves may need to be replaced because the vehicle is tired, I have replaced it 2 times before, but since the problem is caused by the engine pressure, not the valves, I get the Automatic Gear Fault error when replacing the hoses when it repeats.
If the air conditioner is switched on after driving a distance of 50KM, a warning message that allows the vehicle to go in the 3rd gear continuously to protect the engine and transmission, as the engine and transmission assembly get too hot, Automatic GEAR Fault. Short distances are also not errors, but if the Sellonoid Valves have failed when the brain is connected to the computer, it should be replaced, I changed 2 to 840 TL.
Yes, I have honestly summarized the situation. I will be selling my vehicle soon. I know I can't get a car with the same comfort.
What price should I set?
Regards
08.05.2020 21:14 # 2
Hello.
When it comes to the 1-key issue, the card inside is probably now over its life. It will be necessary to make zero between 150-250 TL in auto keymakers.
There are places that repair 2-door locks, my teacher, or if the exit is intact, it is necessary to find a place that can change.
You cannot change locks within the scope of 3-car insurance. However, if you say that your spare key or original key has disappeared, they were making such changes, of course, depending on the clauses in your insurance policy.
4-Actually, you said that it has caused a lot of expense in the last time, and the paint and headlight business was up to you, but it should have been due to the age of the vehicle. transactions to be done if you want to ride the most.
5-If you have a special planting with a seat cover that is not very expensive, it will cost around 400-500 TL.
You have to look at the market for 6-price. even hawk-borners have become 15-20 thousand rubles.
08.05.2020 21:14 # 3
Lsuersoy
[QUOTE = sonerkyl] Hello.
First of all thank you for your comments.
Yesterday I put my car in Motor Service, Walking Maintenance and LPG Maintenance in special services in Kartal Auto Industry.
1 - I changed the V-belt, I replaced the motor flow lower ear = 230 TL including labor
2 - LPG was maintained normally, the filter was changed, the cleaner was used. = 100 TL
3 - I got a Keymaker locked the Center Lock. = 300 TL including labor
4 - I bought the lower ear piece from the piece = 40 TL
nearly 700 TL has been maintained.
In the current maintenance there are 4 parts that need to change in the vehicle. And I don't have to change those parts because those are the parts that provide comfort.
Right-Left Axles are skewed, shudder at 70-85 km of pressure to the gas, after 90, the shake is cut because the vehicle is better grabbed to the ground. There will be no trembling on the long road.
If the axles are desired to be changed, it is possible to get 1 between 390 TL and 3000 TL, both of them used the same or original photo. 390X2 = ~ 800 TL
Transmission for GEAR FAULT error
Replacement of Solenoid Valves and Transmission needed to be changed
Solenoid Valves are between 170-640 TL.
The transmission can be found between 3000-7000 TL. 3000 Bounces, 7000 Zero Chances
If we include the flooring, let's say 500.
My winter tires are 2 years old and PETLAS, My summer tires are 3 years old and GOOD YEAR
I wouldn't want to sell my car if I had all the shortcomings done, because there is no constant hose in the engine section,
There is no oil leakage in the engine, there is no water leakage, I have put 3LT antifreeze twice in the last 3 months, all rust in the system has been removed.
We can say that the vehicle will probably not give the following errors or extra costs for 5 years.
Heater Honeycomb ZERO ORIGINAL manages 5-10 years.
Engine Ears ZERO ORIGINAL, if the pits are not entered according to the usage, the lifetime management is
would.
The headlights were replaced, ZERO BOSCH was renewed.
Body Paint ZERO,
The lock problem is solved with the Central System, there is also a spare key.
The driver CAM and DOOR control console ZERO has just changed.
Now, I am taking my car to auction from 21.000 TL.
I am thinking of selling before the sacrifice feast.
I will sell it to the highest bidder.
Thanks.
08.05.2020 21:14 # 4
You have collected the teacher who was a great expense. Let's say good. The curvature of the axles is not much, and it usually makes that problem from the gap formed in the axle tulips. There are places that perform axle repair, the maximum of 400-500 TL in two axles is solved. I hope you wish to sell your vehicle as soon as possible.
08.05.2020 21:14 # 5
Lsuersoy
Interested Gallery maybe comes out.
I honestly spent a lot of time in auto industries now, it will not be a problem after that, I think low KM, fuel miser, family type, Japanese or German.
If there is no figure in the 27.000-28.000 thousand scale, I will not sell the vehicle and keep it in reserve.
I had to increase the number due to the fluctuations in the exchange rates, because the price of the vehicles I intend to buy is around 20.000 TL, plus the market.
There are those who want 36.000 TL for FULL of my vehicle.
How can the Transmission and Engine states know?
Everyone can show the expertise tool they want.
If I think of swapping with JAPAN or GERMAN with running, I wouldn't pay the difference.
I would like a warranty with 1 year contract.
My own vehicle can only be guaranteed for parts that I have replaced and mentioned above.
Experienced masters who know their job will already estimate the age of the parts.
By the way, I came to mind now that I had the Ceramic Catalyst installed the previous year.
With the vehicle, I will also give you the accessories and accessories that should be in the luggage such as first aid kit, reflector, fire tube.
Port baggage is not included in the prices.
