Peugeot 308 windshield problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (After 2014)
19.11.2023 17:22 # 1
Craven
Hello, I have a 2020 Peugeot 308. The other day, while wiping the windows from the outside, I noticed white spots at the bottom end of the windshield. In the area between the two wipers. Since the car is still under warranty, I took it to the service center and they said the glass needed to be replaced or the glass would have to be removed, the area cleaned and then reattached. I was told that the glass could crack during this process. I took it to a few other places and they said these problems occur with older cars; yours started early. They said there is no solution other than glass replacement and don't touch it. I don't want to replace the glass; I want this problem with the glass to be stopped before it gets worse. No one can say for sure what the reason is. Some say the glass is airtight, some say the glass is watertight, etc. Some say the rain drains are clogged, but I tested it and it's not clogged. I also checked the inside, it's damp - not wet.
19.11.2023 17:24 # 2
Craven
">http://
19.11.2023 17:26 # 3
Craven
">http://
19.11.2023 17:29 # 4
Craven
">http://[url=https://hizliresim.com/4gwq56z][img]
19.11.2023 17:31 # 5
Craven
">http://[url=https://hizliresim.com/pjrkjfl][img]
28.11.2023 08:55 # 6
Hello, sir, this is entirely a manufacturing issue. The glass needs to be replaced. What's the process of removing, cleaning, and reinstalling the glass? For a vehicle under warranty, I recommend contacting Peugeot headquarters first, then another authorized service center. Replacing the glass isn't a major problem; the important thing is that it's done with proper workmanship, and since it's being replaced by an authorized service center, you won't have any problems in the future.
04.12.2023 23:06 # 7
ggitaristt
It seems like the gap between the two windows has started to open from the edges. It started on my 307 too. But after installing the sound system..
