Peugeot 308 - Vehicle Does Not Speed Up
08.05.2020 18:10 # 1
emr_5
Hi friends,
2 months ago, my car's turbo broke down and I replaced it. There was no problem until yesterday. Yesterday, I was driving at 120 km speed, and then the whistling sound came from the turbo took 5 minutes. I started using the tool again and cut off the sound, there was no sound. The engine is operating normally. But the problem is that the vehicle does not accelerate, the speed is increasing, the vehicle does not accelerate, normally, I think the 2nd gear should be activated. What do you think is the problem, is the turbo broken or is it caused by other problems?
I'll be happy if you can help me. Thanks.
08.05.2020 18:10 # 2
The turbo has nothing to do with the gear, but the problem is with the turbo.
08.05.2020 18:10 # 3
As if there is a leg in the turbo He's running somewhere. I think it started to wet with the loosening of the clamp and finally threw the clamp and the turbo was turned off. Hurt the hood and check the hoses.
08.05.2020 18:10 # 4
ahmet_bjk
it turns the turbo on after 1750 cycles, and the whistle sounds when the turbo is running
I don't think the problem will be a turbo if the speed suddenly rises and the vehicle doesn't accelerate at all, it may be something related to the gearbox or the brains,
08.05.2020 18:10 # 5
The same thing happened to me when Leon 1.9 tdi came to me, a whistle like whistle came 2 weeks later, the turbo was completely whistled. After 1 hour, the turbo was completely stopped and the car started to emit black smoke from the exhaust. I said okay, gone turbo or engine. The malfunction lamp was lit, the car was in trouble 70km later found service after the intercooler turbocharged pressure hose 5 cm torn to the turbo. It later improved.
