Peugeot 308 T9 (ENGINE FAILURE)
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (After 2014)
04.11.2024 21:25 # 1
ulamburias
Hello everyone, on November 2, 2024, I took my second-hand car to the Göral - Ümitköy/ANKARA service for its first periodic maintenance. They changed the fuel filter, fuel filter housing, oil filter, oil, and pollen filter, and performed the necessary checks on the vehicle. On the way back at night, the car suddenly lost power and experienced engine failure. I immediately pulled over and called Peugeot roadside service. The technicians we spoke with on the phone agreed that traveling at low speed without straining would not cause a problem, so I continued on my way. While driving, I noticed a decrease in vehicle performance and increased fuel consumption. When we later connected the car to the computer, we found that it displayed the following engine fault codes. I searched online, but people kept coming up with different combinations of error codes, and I couldn't find a definitive solution. Has anyone experienced this problem before or can help with this issue? Error Codes: P00BA - Low pressure fuel circuit Low pressure during injection P2291 - Fuel high pressure system: Fuel pressure too low Start-up time exceeded P1496 - Exhaust gas turbocharger 1 Position above/on nominal value P2563 - Boost pressure regulator Position above/on nominal value
08.01.2025 13:33 # 2
Atmaca1653
Hello, I had the same problems in February 2024, but when the engine failed, it would immediately stall, I could not move the vehicle for about 1-2 hours, everything was checked, starting from the pressure sensor, I went to 5-6 mechanics, and finally I had to change the fuel pump, after the pump was changed, the same problem occurred again during my test drive. This time, I pulled over and removed the fuel cap, it let out a strong air, then I started the vehicle again, and it was giving the error code you stated below, all of which were cleared for me too, the vehicle returned to normal speed, and I continued the journey without replacing the fuel cap, when I explained the situation to the technician, he said let’s clean the fuel and air filters, they are dirty, the problem was solved after a process of 500 TL, it has not recurred in 1 year, fuel pump replacement etc. were all wasted. I registered to make this comment, I hope it helps someone.
10.01.2025 20:50 # 3
tayfux
It seems like the car is having a hard time getting fuel, sir.
