peugeot 308 star-stop problem? (2015-)
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (After 2014)
08.05.2020 21:13 # 1
milyoncubaba
Hello there,
The star-stop of my vehicle in the 2015 model 45 thousand stopped working.
I did a battery measurement, there is no battery problem. no error code etc. When the vehicle is stopped, the eco lamp flashes but the star stop is not activated.
what could be the problem
I am waiting for your ideas, suggestions
08.05.2020 21:13 # 2
Although my battery seems to be intact, it does not run below a certain value. Also, if your seat belt is always fastened, you can face such problems.
08.05.2020 21:13 # 3
samet2461
If the seat belt is always fastened or if the buckle is tied so that it does not sound, the start stop does not work by detecting that it is always fastened.
08.05.2020 21:13 # 4
milyoncubaba
I wear the seat belt all the time, before I start the car, there is any setting etc on the smag screen, or I am going to tamper with something else.
very interesting. On the day I bought the vehicle it worked other days it never worked for almost 2 months. I use the vehicle very little 300 400 km I did not.
08.05.2020 21:13 # 5
You have used very little, since my teacher probably does not charge your car battery sufficiently, the vehicle start-stop is not activated. Observe when you drive at least 50-100 km like this, it will probably start up. Not on the screen, my teacher will have an eco button on the left.
Special cases: STOP mode is unavailable STOP mode is not specifically activated when: - the vehicle is on a steep ramp (uphill or downhill), - the driver's door is open, - the driver's seat belt is not fastened, - the vehicle's speed since the engine was last started by the driver Not exceeding 10 km / h, - electric parking brake is applied or towed, - maintaining the vehicle's thermal comfort requires this, - the defrosting function is activated, - some instantaneous conditions for the control of the system (battery charge level, engine temperature, brake assist, outside temperature. ..) requires this.
08.05.2020 21:13 # 6
milyoncubaba
that is, did you mean that the battery did not come into operation because it was not working enough even if the power measurement was not sufficient? Yes, it makes sense that I do 100 150 km a week, I do not do this level.
08.05.2020 21:13 # 7
milyoncubaba
Is there a topic I wonder?
I saw the error codes section on the vehicle screen. Do you ever notice that the technical problems in the vehicle are reflected on that screen exactly?
So when the pc is connected to the vehicle, do the errors that fall there think of the segmentation on the smag screen?
08.05.2020 21:13 # 8
[QUOTE = million people] I have a question I wonder about?
My teacher gives a general problem warning in case of malfunction. engine failure - like the dpf level but the healthiest is always connecting and looking at the pc.
08.05.2020 21:13 # 9
Did you mean that [QUOTE = millioncab] was not working because the battery's power measurement was not working enough even if it was not enough? yes it makes sense I do 100 150 km a week, I don't do it at this level. [/ QUOTE]
the battery is not fully charged due to the short distance, although it is healthy.
08.05.2020 21:13 # 10
milyoncubaba
thank you for the informations.
Finally, how can I reduce the sounds coming from the back doors?
While opening and closing, a lot of noise is heard from the tensioners above normal.
08.05.2020 21:13 # 11
pusutr
[QUOTE = million people] thank you for the information.
I guess you are talking about sound. I apply grease, almost every 2 months. Despite this, there is a noise again.
08.05.2020 21:13 # 12
milyoncubaba
so starstop is still not tribal running :)
08.05.2020 21:13 # 13
Hasbinabd
[QUOTE = million people] so starstop is still not tribal running :) [/ QUOTE]
Master, what's the final situation? It doesn't work on the vehicle I just bought start stop. Altogether from the battery. Their battery is more expensive than regular batteries. It is difficult for the battery to amortize itself with its economy from start stop :) Meanwhile, the only solution to the door sound is to change the tensioner. I took the original door tensioner from here and changed it myself
Hasbinabd 2019-06-28 10:21:43
08.05.2020 21:13 # 14
[QUOTE = Hasbinabd] [QUOTE = millioncababa] so starstop is still not tribal running :) [/ QUOTE]
In fact, the manufacturing companies say that they have made savings, but how much does it make?
08.05.2020 21:13 # 15
ablkbs
If the eco lamp is blinking but not activated, this is something that the vehicle does consciously,
Either the engine temperature is low
Or your air conditioner is on and it is in hi or lo position. If the air conditioner is in hi or lo position, start stop is not activated, degree must be entered.
If there is a serious difference between outside temperature and inside temperature, start stop will not be activated.
If there is a malfunction in the start stop system, eco will go off continuously when you start the vehicle.
ablkbs 2019-07-13 13:31:01
08.05.2020 21:13 # 16
Akil
The same problem was also in my vehicle, starting from 40,000 km, start / stop was not activated as you said, when I was running the vehicle like 60.000 km, a saving mode appeared on the screen. ) There is no problem right now, start / stop has started to be activated now. In other words, the problem mentioned indicates that the last year of the battery has been entered.
11.08.2021 14:15 # 17
Erkam Gecen
Good day, our vehicle is 2020 model 3008 at 12 thousand km or something. Since we live in Alanya, the weather is extremely hot and the car stays in the sun while at work. We put a sunshade or something so that it does not go inside, but there is nothing to protect the outside. When I press the start stop button, it says the temperature is incompatible and it turns on and off 2-3 times, and finally it stays off. Does anyone know why?
11.08.2021 16:36 # 18
ayd1903
You better work
04.11.2024 09:10 # 19
ulamburias
[QUOTE=milyoncubaba]So, starstop still doesn't work with tribal :) [/QUOTE] Hello sir, did you find a solution to the problem? I have the same problem right now. I wonder if it's because of the battery?
13.11.2024 09:00 # 20
wolkan35
I HAVE THE SAME PROBLEM. I CHANGED THE BATTERY. (70 APER AGM BATTERY) START-STAP FLASHES AND DOES NOT WORK. OCCASIONALLY IT SENDS A SERVICE REQUEST AND GIVES AN ENGINE WARNING. HAS ANYONE FOUND A SOLUTION?
Page : / 2
