Peugeot 308 Multimedia Screen Recommendation Need
08.05.2020 21:17 # 1
oguzkaan78
The vehicle is a 2010 model Peugeot 308 1.6HDI Comfort. We will be looking for a screen that accepts a budget below 2000 tl (1400-1500 TL band is the most convenient for me). (better to have a rear view camera)
There are a lot of them on the market, but if I think there are no users, because there are no comments, I was able to find the following.
oguzkaan78 2019-07-17 23:02:00
08.05.2020 21:17 # 2
The first product is very beautiful, but in case of a breakdown, the issue of spare parts and repair is important.
08.05.2020 21:17 # 3
always_sb
I think we are using the same vehicle, and I got the multimedia screen, cruise control, rear view camera system and the new generation gear knob after I bought the vehicle. I have no trouble. they all work very stable. I think navimex is an ideal brand price in the range you think.
08.05.2020 21:17 # 4
oguzkaan78
Do you use navimex in your vehicle? I will have questions
08.05.2020 21:17 # 5
always_sb
my avgo in my car got my friend navimex with me. navimex 250 tl was more expensive. but there is not much difference from the pain of use. Both of them are fully compatible with the vehicle. As far as I can see, navimex is only faster in reading the card, when it inserts a 64 sd card, it detects a lot of nights and sometimes skips, I saw that this problem is not with my friend. I found the solution for this by inserting a 16-card. If you have anything in mind, you can ask and it takes a very long time to assemble and I think whatever you get, the thing you need to pay attention to is the installation work for the master.
08.05.2020 21:17 # 6
oguzkaan78
[QUOTE = always_sb] avgo in my car got my friend navimex with me. navimex 250 tl was more expensive. but there is not much difference from the pain of use. Both of them are fully compatible with the vehicle. As far as I can see, navimex is only faster in reading the card, when it inserts a 64 sd card, it detects a lot of nights and sometimes skips, I saw that this problem is not with my friend. I found the solution for this by inserting a 16-card. If you have anything in mind, you can ask and it takes a long time to assemble and I think whatever you get, the thing you need to pay attention to is the installation work that you have done to the master ... [/ QUOTE]
In some places, navimexin does not work, the arm in the vehicle does not work, they say that the button is not working, is there any problem with your friend? For example, there is a hardware key defect, software, muscle freezing, etc.
08.05.2020 21:17 # 7
oguzkaan78
Do you also have the wiper adjustment daytime running light settings like the original tape on these tapes?
08.05.2020 21:17 # 8
always_sb
Both models do not have arm and knob adjustments like every han that does not work both avgo and navimex. I think the complaints you said are related to the wearer. They coded in a row because it was not the first time I had the cruise control installed, but after that we saw that it was activated after 4 gears. In other words, there is no problem like software or arm like every inn. You can make the settings you want from the multimedia screen. daytime running lights, vehicle malfunction control etc. can be made a few adjustments. let me talk about a problem there. Although the installation is in Turkish, some sentences are not written in Turkish in the multimedia screen settings section, but I do not know if this is all of them, but in other parts there is a 100% Turkish menu.
08.05.2020 21:17 # 9
always_sb
And you said it was not freezing, I did not have anything like that, but the first thing I said was that you can install a 64 sd card, 128 sd card or flash memory but when you insert it full, there are problems such as night reading, clip or song skip, and I inserted a lower memory sd card. I produced a solution, I have no problems at 16 gb.
