Peugeot 308 HDI Auto 6R Engine Sound
08.05.2020 19:22 # 1
wesley09
Hello there,
1 month ago, 2011 model 308 HDI Auto 6r (112) was purchased. The vehicle is 2011 model and 44.000 KM de.I am sure that all the maintenance has been completed since I got to know the first owner of the vehicle closely. filters oil discs etc.)
However, there is a voice in the vehicle that I cannot understand.
When I press the gas, there is a noise from the engine. I asked the master about the injector. Injector exercise should be done. Also, when the vehicle exceeds 130, there is a slight thing that I cannot understand if I say vibration or hit.
Has anyone faced a similar situation before?
Does the so-called injector exercise really resolve the sound?
Thanks in advance.
08.05.2020 19:22 # 2
I think they should take the problem to a service first, they will say the price is cheap, but then you will say I will do it and you will find out why the problem is caused. As far as I know, they do not charge for fault detection in services.
08.05.2020 19:22 # 3
Efe-Pojo
[QUOTE = sonerkyl] I think take them to a service first, if they find the problem, they will say the price is cheap, but then you will call it and you will find out why the problem is caused. As far as I know, they do not charge for fault detection in services. [/ QUOTE]
If you don't count 100 liras, they don't.
I will look at the service and go out from 100 lira friends, if you do not like to rain money, I think don't stop by.
08.05.2020 19:22 # 4
[QUOTE = Efe-Pöjo] [QUOTE = sonerkyl] I think that if you take it to a service first, they will find the problem, they will say the price is cheap, but then you say I will do it and you will find out why the problem is caused. As far as I know, they do not charge for fault detection in services. [/ QUOTE]
it is true teacher I have never been to the authorized service so far :) not less than 100 TL
08.05.2020 19:22 # 5
wesley09
I just connected the vehicle to the computer and had it fixed. They said that 3 of the injectors were defective and that they should be replaced. The one was around 500 TL.
Is there a chance to correct the malfunction in the injectors? Could you help me with experience or knowledge before?
08.05.2020 19:22 # 6
get past teacher bad situation 3 injector 1500 TL injector maintenance is done I guess experienced friends inform but change the place where you took the fuel ..
08.05.2020 19:22 # 7
xmen
Sir, first of all, unfortunately, injectors are expensive parts. An abnormal situation for only 45 thousand vehicles ...
08.05.2020 19:22 # 8
wesley09
Thanks friends.
Monday I will show it to a master who is an expert in injector and put it into the injector test. If it is repairable, we will look for a solution without changing it.
08.05.2020 19:22 # 9
I looked at my teacher a little bit, I have many people like you on the service who have experienced the same problem with the software update or something, but you still have a good research.
08.05.2020 19:22 # 10
Alicilik
Where's the car?
Did you practice injectors?
08.05.2020 19:22 # 11
wesley09
Hello sir,
The vehicle was in Ankara. I had taken the vehicle to the Fatih Peugeot service for the injector exercise, because of the creaking noise.
I also think of showing the job on Monday to a master with injector diesel pump.
What is your suggestion?
08.05.2020 19:22 # 12
wesley09
We solved the problem. To explain it briefly;
There was a problem with the injector valves (in 3 of them) While it had to cut the diesel, it did not cut the diesel, so there was a diesel accumulating in the place called the injector billet. There is a very noticeable difference in the vehicle. The sound was cut off completely and the traction increased. I cannot say anything since I have no chance to measure the fuel yet.
I want to inform you.
08.05.2020 19:22 # 13
I am glad that your problem is solved, my teacher.
