Peugeot 308 Flickering Problem at Takeoff
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (After 2014)
22.06.2020 16:26 # 1
tobeornottob
We bought 2020 model 1.2 puretech peugeot 308 (automatic transmission), but the vehicle is shaking very much during take-off. This tremor stops when the vehicle accelerates a little. Does this occur with friends who have the same vehicle?
22.06.2020 23:35 # 2
Eleman1987
Get well soon. If the engine mounts are in good condition, it can be corrected by clutch calibration. My vehicle was doing this when the battery changed. The service would download the transmission. He said that calibration is not on these vehicles. But I got it done in industry. If you want to give it a try, you won't lose anything.
25.07.2020 23:48 # 3
wacd
If you have the opportunity, when you go to the service, request a test drive with a vehicle of the same generation and compare. If you are used to the classic 4-cylinder engine characteristics, the 3-cylinder 1.2 engines may seem a little strange to you. It is already said that it works one click more vibratively at lower speeds than normal.
27.07.2020 10:36 # 4
In my opinion, fully automatic gearboxes should not be this problem, sir. Ask if there is a software update in the authorized service regarding the engine. As our friend said, I think the problem can be solved with the transmission caliber.
27.07.2020 11:24 # 5
06ahmetcantoprak
Since 3-cylinder engines do not have a reciprocating piston, they work with vibrations. I have 2020 308 1.2 Puretech Eat8, as you said, this is normal anyway, be comfortable. 06ahmetcantoprak2020-07-27 11:25:22
30.10.2020 16:34 # 6
aaktas
Dude, did you take the car to hello? It would be nice if you could cite the latest developments.
09.09.2021 00:14 # 7
experta
Hello there,
I'm thinking of buying a 2020 1.2 puretech 130hp vehicle. But I'm undecided about the engine
Is there a chronic malfunction etc. of the engine?
Do you recommend 2018 1.6 BlueHdi Eat6 or 1.2 puretech eat8?
