Peugeot 308 e-hdi start stop problem hk
12.12.2023 15:55 # 1
yunuserk
Hello, I replaced the battery in my 2013 E-HDI because the start-stop function wasn't working except on long trips. After replacing the battery, my car stops at traffic lights or when I'm stopped, but it doesn't start when I take my foot off the button again. I have to manually start it. The tensioner belt, battery, and everything else have been replaced, but the problem hasn't been resolved. Has anyone else experienced this?
13.12.2023 09:19 # 2
Hello sir, have you checked the error codes of the vehicle? I recommend you to have it checked, especially with the original software.
13.12.2023 09:31 # 3
yunuserk
Hello again, sir. Thank you for your interest. I couldn't have the original device checked because it wasn't available in my city. No codes or error messages were found on the devices I installed.
13.12.2023 12:08 # 4
[QUOTE=yunuserk]Hello again sir, thank you for your interest. Since the original device is not available in my city, I could not have it checked. No codes or error records were found in the devices I had installed[/QUOTE] If you need anything in Ankara, you can contact Mass Pegeot - Şaşmaz or Peugeot private services. They have devices, sir. Unfortunately, many details are not visible in universal products.
08.06.2024 14:06 # 5
yunuserk
Hello Friends, Niyazi, a specialist at Kırıkkale Çözüm Oto, has found a solution. Through his tests and implementation, he determined that the problem was with the tensioner assembly installed in the aftermarket. He said that the start-stop function wasn't activated because the tensioner wouldn't release itself. I purchased the Euro 5 engine tensioner from Hakan Pejo in Ankara, based on the chassis number, for 3,850 TL. We installed it, and the problem was solved. This clearly indicates that the original part should be used.
