Peugeot 308 Automatic Gear Problem
08.05.2020 18:49 # 1
cloude33
Good day, friends.
2008 model type electronic gear LPG (Landirenzo Brand) 308 1.6 Vti 120 BG I own the car.
The Failure in My Vehicle is That When the gas level drops and the fuel light turns on, the transmission puts itself into the Limp Home (limping) Mode . This means that. Gear does not go above 3. You can't use manual gear. The car gets heavy like a truck. In addition, with this limp home mode, problems with knock-on operation and shaking begin. When you take gasoline and turn off the fuel light, the transmission exits the limp home mode, but if you do not turn off the fault light, flickering and knocking continues. Since the vehicle is LPG, the fault light is always on. It is not yet possible to figure out where this problem originated from. They said that the PSA module was installed on LPG Vehicles for the gas gauge problem and when we started each vehicle, they said that we could reset the gas gauge and show the correct gasoline level. If I used this vehicle, which was worn on my head, with gasoline and when the gas light was on, I would always have this problem. I need your information and comments on the solution of this problem. Thanks in advance for your help.
08.05.2020 18:49 # 2
mami202
`` If I used this vehicle that stuck in my head with gasoline and when the gas ran out light was on, I would always have this problem. `
I don't have a definite solution idea about your problem.
Try to use the gasoline tank only with gasoline until the light turns on, you see what happens when the light is on, yet I do not think it will be a problem related to the burning of the gas light.
08.05.2020 18:49 # 3
cloude33
Thank you for your opinion, but I used gasoline, and when the gas gauge came on, the car got the same shape. There's a problem that puts it into the automatic gearshift mode, and I'm trying to solve it.
08.05.2020 18:49 # 4
cloude33
I am still unable to solve the problem.
08.05.2020 18:49 # 5
xblax06
we have a problem solved so we have
08.05.2020 18:49 # 6
cloude33
The problem is solved because I got a complete engine spent 4500 TL. no problem for now
I replaced the oxygen probe.
LPG regulator changed
LPG inj Maintenance Done
LPG Brain Software The proper configuration for the vehicle has been loaded and the engine no longer lights.
I have been riding the vehicle without any problems for 2 years now until I know the vehicle :))
cloude33 2016-04-14 20:16:00
