Peugeot 308 1.6 VTI overheating problem
22.02.2022 23:45 # 1
fatihkara26
Good forum everyone, I'm new among you, something happened to me that I couldn't solve. I would be very happy if friends who know and understand can help
We just bought the vehicle, there was no antifreeze, I had antifreeze put in, I drove about 1500 km, then the vehicle overheated, left on the road, blown the hose, I had it done 2 weeks later, we were on the road again, it overheated, we got it done again
Read More Then I realized that the radiator upper hose is quite swollen when the temperature reaches exactly 90. I see, I can't drive the car because the lower hose is cold and it will blow up the hoses again. I changed it because the thermostat does not open, the lower hose heats up, but it heats up late, again the fan turns on very short, it works for 5 seconds and turns off, the upper hose is still swollen I am afraid to go on a long journey.
23.02.2022 14:01 # 2
Hello, when there is no antiriz, it is not known where the car will explode, my brother. because the water has eaten rust and lime everywhere. When you use the antifreeze, it causes trouble wherever it clogs. The only thing to do will be a little costly, but
1-replace the radiator for sure
Change the 2-circulation pump.
Check 3-heater radiator, is there any blockage.
4-Use quality antifreeze absolutely and definitely. shell - total - like castrol
5- clean the system.
