Peugeot 308 1.6 Hdi Automatic gear shift problem
08.05.2020 20:35 # 1
Tunahanhos
I have friends peugeot 308 1.6 hdi auto6g envy model car. Semi-automatic vehicle. Even though it is in automatic mode, we need to use the automatic atmio gear, that is, if it is in manual mode, the vehicle runs 2-3 times, and it is leveled after doing the istop. Does anyone have such a problem?
08.05.2020 20:35 # 2
uzunca961
Well, my teacher may have different reasons. Does the car fail, you need to know it.
It's likely to be related to the brain. Sometimes the brain is damaged auto goes away and only allows manual use
08.05.2020 20:35 # 3
Tunahanhos
It doesn't go wrong, auto text is only going
08.05.2020 20:35 # 4
talip206
As the pressure decreases in the semi-automatic, the transmission starts to miss the grip point. Usually, the computer calibrates the gearbox and exercises and the problem is improved. It is useful to go where the original software is and get it done
08.05.2020 20:35 # 5
uzunca961
It is necessary to look at it by connecting it to the computer. If you have a good pejo for citroen, a show is not so simple.
08.05.2020 20:35 # 6
Tunahanhos
Did they update the version, would it be useful for this luck
08.05.2020 20:35 # 7
uzunca961
[QUOTE = Tunahanhos] Update version, they would say it would be useful for this luck [/ QUOTE]
My teacher usually tells me to update the version.
Most of them say don't do pejo cu.
I do not think that your distress will improve with the update, but you know
08.05.2020 20:35 # 8
atahan
Sister good evening looking for answers to your problem on the internet
I saw the problem, I have the same problem.
I wonder if you solved the problem, can we help
My vehicle ta 2011 diesel auto
08.05.2020 20:35 # 9
[QUOTE = atahan] Brother good evening is looking for an answer to your problem on the internet
teacher first connect the pc and look at the error codes. If there is no problem, have cablibration done. At night, remove the battery terminal of the vehicle and check again in the morning.
25.04.2022 11:47 # 10
halamadrid
Sir, I am having the same problem. Did you solve your problem?
29.04.2022 11:11 # 11
yakupsaritas
When I put it in A mode at the first start, the vehicle would automatically shift into 1st and 2nd gear with a loud and knocking sound. I went to the authorized Peugeot service in Denizli. 500 ml of oil was reduced in the gearbox and they practiced the gearbox. In October 2021, it cost me something like 250 TL. 2011 1.6 hdi comfort pack 308 74 thousand km more
07.07.2022 12:12 # 12
Tahir77
Hello, I became the owner of my 2013 model 5008 vehicle while driving on the road, the automatic transmission was canceled and my vehicle could only be used as a manual gear, besides, while the rpm could exceed 3000 in the first three gears, the rpm could not exceed 2000 in 4 5 6, so the vehicle turned itself off in a way. No matter how hard I tried, even if I turned it on and off, the fault did not go away, I read many articles in the forums, some of them were writing three times on and off, some of them were saying that by removing the terminal of the battery and plugging it. I had the car connected to the computer. There was no obvious transmission malfunction in the car. Looking at other issues, there was a malfunction saying that your particulate filter needs to be changed. I went to the industry in Ümraniye and could not get any help from the tradesmen there. Those who say let's clean it for 600, those who say the liquid is gone, let's change it to 1200, everyone is taking it out, and those who say we can fix it for 650. I did not trust any of them. I went to Kadosan Industry and asked if there was a reliable tradesman there. They told me about SRT OTO serhat. He said that the fluid connected to the filter might have run out, he completed the fluid, then computer celebrations were held and after these adjustments and corrections, my vehicle's transmission malfunction was also resolved. When the liquid ran out, the vehicle protected itself. In total, I was done for 600 TL including liquid. Citroen Peugeot is a complete competent and very trustworthy person in the field of vehicles. While doing the job, he tells you the event and gives you information. I gave the right without any bargaining. After that I found my master. I advise.
07.07.2022 12:14 # 13
Tahir77
I became the owner of my 2013 model 5008 vehicle while driving on the road, the automatic transmission was canceled and my vehicle could only be used as a manual gear, besides, while the rpm could exceed 3000 in the first three gears, the rpm could not exceed 2000 in 4 5 6, so the vehicle turned itself off in a way. No matter how hard I tried, even if I turned it on and off, the problem did not go away even if I removed the battery, I read a lot of articles in the forums, some of them were writing three times on and off, some of them were saying that by removing the terminal of the battery and plugging it. I had the car connected to the computer. There was no obvious transmission malfunction in the car. Looking at other issues, there was a malfunction saying that your particulate filter needs to be changed. I went to the industry in Ümraniye and could not get any help from the tradesmen there. Those who say let's clean it for 600, those who say the liquid is gone, let's change it to 1200, everyone is taking it out, and those who say we can fix it for 650. I did not trust any of them. I went to Kadosan Industry and asked if there was a reliable tradesman there. They told me about SRT OTO serhat. He said that the fluid connected to the filter might have run out, he completed the fluid, then computer celebrations were held and after these adjustments and corrections, my vehicle's transmission malfunction was also resolved. When the liquid ran out, the vehicle protected itself. In total, I was done for 600 TL including liquid. Citroen Peugeot is a complete competent and very trustworthy person in the field of vehicles. While doing the job, he tells you the event and gives you information. I gave the right without any bargaining. After that I found my master.
