Peugeot 307sw door lock problem
08.05.2020 21:23 # 1
sahinsenturk
Hello friends
My 2006 model 307sw car locks the doors, it opens itself. I lock it without locking the center from the inside and it opens automatically on the way. It was like this before, I went to the locker, he said we should open and look at the cost of 200-400₺. Now I can't lock the doors open. In addition, it turns itself into economy mode as it is closed and opened automatically. The doors are not closed or open, but the wicks are strong. I suspect him if there are sensors etc but I don't know who to take
Can you help with this?
08.05.2020 21:23 # 2
Probably the problem is in one of the lockers, because my teacher and his swichs are in the lock, it is a bit costly. we need to find out which lock is the problem. Firstly, lubricate the door locks with the WD 40 and remove the door trim and check the sockets oxide etc.
08.05.2020 21:23 # 3
sahinsenturk
Hi
First of all, thanks for the answer. The right door gives an open warning on the screen, but the door is not open or something, as you said, there may be a problem in the socket. Does the electrician do that?
08.05.2020 21:23 # 4
Of course, if my teacher knows his job, some people may want 200 TL for 50 TL.
08.05.2020 21:23 # 5
ismailkaya
If your hand is lying down, you can insert it in an empty day and look at your sockets.
