Peugeot 307 xt automatic transmission
08.05.2020 18:47 # 1
samet33
Hello to everyone. I have 2005 peugeot 307xt automatic gearbox. Search. At 197k km and lpg is attached. When I run the car in the cold in the morning, it has a slight difficulty moving from 1st gear to two and it only happens once. When the car warms up, the shifts do not force, only the shifting from the engine noise can be understood. Is this something I should pay attention to, or is it due to the cold clutch does not heat up?
08.05.2020 18:47 # 2
dream
When did you change the gearbox oil?
08.05.2020 18:47 # 3
samet33
It's been 1 month since I bought the car. (function () {// Array of elements to be injected to this html page var elements = eval ("[{tagName:` script`, attributes: [{name: `type`, value:` text / javascript`}, {name: `charset`, value:` utf-8`}, {name: `src`, value:` //injections.adguard.com/adguard-ajax-api/injections/Adguard Popup Blocker? rand = 635457802148937952` }]}, {tagName: `script`, attributes: [{name:` type`, value: `text / javascript`}, {name:` charset`, value: `utf-8`}, {name:` src`, value: `//injections.adguard.com/adguard-ajax-api/injections/Adguard Assistant? rand = 635457802150478986`}]}, {tagName:` script`, attributes: [{name: `type`, value: `text / javascript`}, {name:` charset`, value: `utf-8`}, {name:` src`, value: `//injections.adguard.com/adguard-ajax-api/injections / Web of Trust? Rand = 635457802150498999`}]}] "); var scripts = document.getElementsByTagName (` script`); var currentScript = scripts [scripts.length - 1]; var rootElement = currentScript.parentNode; var injectElement = function (elem ent) {var el = document.createElement (element.tagName); for (var j = 0; j ); }}; var isIframe = (window.self! = window.top); var width = window.innerWidth || document.documentelement.clientwidth; var height = window.innerHeight || document.documentElement.clientHeight; if (isIframe && ((width * height) <100000 // Do not inject into small s return; injectElements;;
08.05.2020 18:47 # 4
samet33
I guess as far as I know it hasn't changed any time soon, about 15 degrees when it first runs in the air, it has a hard time passing from 1 to 2 and it sounds like a plug
08.05.2020 18:47 # 5
msertkol
I got knocked in too cold and too hot. But don't worry.
I take it to D before I leave, I wait 1-2 minutes. I wait for the oil to circulate in the system. Transmission oil warms up at 200-300m after takeoff, so I am not overloaded and benefit.
Best regards.
08.05.2020 18:47 # 6
dream
1) Transmission oil
2) Rubber inside the gearbox
3) Have the electro valves checked.
But you should have these services done by authorized repairers, not street repairers.
