Peugeot 307 XT 1.6 Steering Problem
08.05.2020 17:53 # 1
TheLife
Hello friends Car Peugeot 307 XT 1.6 petrol 2004 model
There is no sound trouble in my car. There is no abnormality in walking. However, the steering gets harder from time to time. This is not normal hardening because the steering is not turning. I stop the car and run it again. In this case, it is usually experienced after stop and stop when the vehicle is stuck in traffic.
I just changed the tires and made the balance settings.
What do you think could be the problem.
08.05.2020 17:53 # 2
hsnsnl
if you check your oil etc .. you can test it again after that .. if it continues it may be necessary to show that it may be a problem in the engine
08.05.2020 17:53 # 3
This problem can be experienced in cases where hydraulic oil is more than necessary.
08.05.2020 17:53 # 4
TheLife
[QUOTE = koliva] This type of problem can be experienced in cases where hydraulic oil is more than necessary.
I'll check this out.
