peugeot 307 warning lights
08.05.2020 14:53 # 1
goktug
friends, peugeot 307, a warning lamp is on and the flashing stop on the screen. If you know that the warning light in question has two wavy bars underneath and a box with a lid on it, please help me.
08.05.2020 14:53 # 2
t@lip
You can look at the user manual, both on the site and at www.peugeot.com.tr . Get well soon..
08.05.2020 14:53 # 3
goktug
thanks...
08.05.2020 14:53 # 4
araknit
First of all, my friend is past ... the antifreeze must be finished. Check the water if STOP text is flashing.
08.05.2020 14:53 # 5
sirri99
I have the same problem in the same model. is the problem in the antifreeze? my car is doing especially when the engine is hard. I would appreciate if you help. thanks.
08.05.2020 14:53 # 6
sirri99 we would appreciate if you follow the forum rules too.
Our members who have completed their new membership and entered the forum, please introduce yourself by opening a new topic under the heading "Let's Know Our Members ". Filling in all the information will help us to know you better.
1.- Your name and surname:
2.- Your age:
3.- Your vehicle (Brand, model):
4.- Your hobbies:
5.- Your profession:
6.- Where did you hear the site:
7.- Your Blood Group:
8.- Your horoscope:
9.- The team you support:
10.- Which county or province are you in:
11.- Your MSN address:
Thank you for your attention.
Peugeot Turkey Fun Club Management
Www.peugeotturkey.co & www.peugeotturkiye.co I
08.05.2020 14:53 # 7
gozem
Watch out brothers who run out of car.
08.05.2020 14:53 # 8
hasan
look at the water warning lamp water
08.05.2020 14:53 # 9
sirri99
Sorry guys, I'm a little ignorant. so I want to ask here. Do I need to add antifreeze or water? If I will add antifreeze, which brand should I add? and how do I add them exactly? I would be glad if you help. thanks...
08.05.2020 14:53 # 10
metin
Add antifreeze water. I even heard that some of them just put antifreeze instead of water. I think the brand is not important.
First of all, you have to open a topic that introduces yourself in accordance with the forum rules. then you should fill out your profile information completely, then you should write the brand model non-engine engine volume of the vehicle in the signature section. For example, since I don't know what your vehicle is, I can't say where to add the water.
08.05.2020 14:53 # 11
[QUOTE = text] Add antifreeze water. I even heard that some of them just put antifreeze instead of water. I think the brand is not important. First of all, you have to open a topic that introduces yourself in accordance with the forum rules. then you should fill out your profile information completely, then you should write the brand model non-engine engine volume of the vehicle in the signature section. For example, since I don't know what your vehicle is, I can't tell you where to add water [/ QUOTE] I just wondered how they're putting antifreeze. If so, there is a huge misconception that is probably caused by ignorance and straight logic. Let me explain a little bit. The substance we say antifreeze is ethylene glycol (ethylene glycol). This substance is resistant to freezing due to its chemical structure. There is a similar type of diethylene glycol which shows the same feature. This substance is also used as wiper water. When we get pure antifreeze on our vehicles, we need to add water to it. This is because the combination of ethylene glycol molecules and water molecules converts into a solid crystal structure. The formation of this structure also lowers the freezing point of this compound. Meanwhile, the freezing level of pure antifreeze is -12 degrees. When we look at the table below, we can see how much water we add, which freezing point our compound has. As you can see, we are 70% antifreeze, 30% water mixture gives the lowest freezing point (-51 degrees). Since our country does not have cold temperatures below -20 degrees, we are usually 50% antifreeze and 50% water mixture. Percent of Ethylene Glycol Freezing Point (degrees C) 0 0 10 -4 20 -7 30 -15 40 -23 50 -34 60 -48 70 -51 80 -45 90 -29 100 -12
08.05.2020 14:53 # 12
sirri99
firstly the problem was running out of water. thank you to everyone who answered. I did not put antifreeze. I just put water. will there be a problem? I also opened the title introducing myself before my second message yesterday. thank you to friends who still warned. I guess there's really a lot to learn from here ... :)
08.05.2020 14:53 # 13
I do not know the degree of cold in winter since the city you are in does not write the location, but you should have some antifreeze depending on the average situation. It both prevents calcification and reduces the degree of freezing of water in cold weather.
[QUOTE = sirri99] firstly the problem was running out of water. thank you to everyone who answered. I did not put antifreeze. I just put water. will there be a problem? I also opened the title introducing myself before my second message yesterday. thank you to friends who still warned. I guess there's really a lot to learn from here ...:) [/ QUOTE]
08.05.2020 14:53 # 14
Engin Tepe
For example, in a warehouse under Istanbul conditions, we put 1 in 5 depots in the warehouse, if you fill the full antifreeze, you can stop the smell, especially in hot weather :)
08.05.2020 14:53 # 15
In summer, antifreeze does not matter, it can be water, but at least 30 percent of it should be antifreeze in winter conditions in Istanbul.
08.05.2020 14:53 # 16
sirri99
thank you so much. we're going to add antifreeze that means some.
