Peugeot 307 Vehicle Identification and Identification
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 14:08 # 1
hasimayaz
AXXB25K1 - 307 IDENTIFICATION TOOLS 1 - IDENTIFICATION (A) Vehicle manufacturer's plate. (B) Dam n ° - Sequence n ° - Paint code. (C) VIN-number. (D) Air (inflation) pressure - Approved tire sizes (Left front door inlet). (E) Fuel recommendations. (F) Oil instruction label. 2 - VARIABLE TYPE VERSION (TVV) Vin always consists of 17 characters and includes especially the type and version (Additional change definition or chassis number types). 2 - 1 - DIFFERENT TYPE VERSION (TVV) CODING STRUCTURE Type: (G) 1st character = class (vehicle) (H) 2nd character = vehicle (I) 3rd, 4th, 5th characters = engine (regulation type) Print: ( J) 6th character = gearbox type + emission level Variant: (K) remaining characters = complementary description 2 - 2 - CHANGE OF VARIABLE TYPE VERSION (TVV) CODE Type: class: 3 = T50 - T51 appearance: A = 3-door sedan type - C = 5-door sedan type Engine (Regulation type): KFW = TU3JP / L5 / L4 / US94 gasoline engine (engines) K6C = TU3JP / K gasoline engine (engines) NFU = TU5JP4 / L5 / L4 / US94T gasoline engine (engines ) RFN = EW10J4 / L5 / L4 / US94TW petrol engine (s) RHY = diesel engines DW10TD / L3 / L4 / K / W3 models L3W3 L4 L5 US83 / 87 manual transmission (5 ratios) ABCP automatic transmission (4 ratios) DEFR manual gearbox (6 ratios) - GHS differential and / or gearbox ratios differ fundamentally JK L5 T other combination possibilities - no MNU gearbox Z model s other taiwan K / K` alcoholL3 / L4 manual transmission (5 ratios) V 1 5 8 automatic transmission (4 ratios) W 2 6 9 manual transmission (6 ratios) X 3 7 - differential and / or gearbox ratios differ fundamentally Y 4 - 0 other combination possibilities - no gearbox Z variables code code convertible structure T lpg dual fuel GPL (cylinder tank) GL (cylinder tank) stepped emission gases D (private or van commercial vehicle with non-convertible feature) TD (convertible commercial vehicle) financial incentive IF 3 - AIR PRESSURE LABEL (1): Air (inflation) pressure. (2): Tire sizes. (3): Approved tires. (4): Dam n °. (5): Sequence n °. (6): Paint code. (7): Control tolerance of tire inflation pressures.
08.05.2020 14:08 # 2
IsmailAtes
Nice sharing Thanks Haşim abi ..
Does the abbreviation called VIN have anything to do with the electrical system?
08.05.2020 14:08 # 3
okan77
Thanks ... 307 users should know.
08.05.2020 14:08 # 4
selcuk-307
Brother, health in your hands ...
08.05.2020 14:08 # 5
hasimayaz
[QUOTE = AteSH] Good sharing Thanks Haşim abi ..
Does the abbreviation called VIN have anything to do with the electrical system? QUOTE]
& nbsp;
The code used to determine the VIN vehicle ID. VAN is the type of vehicle operating system (Can Can or Can Van) Vin value is kept as the identifying information in Bsi of the vehicle.
& nbsp;
& nbsp;
hasimayaz 2010-01-14 21:16:26 < / editdat a>
08.05.2020 14:08 # 6
H-a-d-i
It is very difficult to find this information even at authorized services. Haşim brother, you're big ...
08.05.2020 14:08 # 7
IsmailAtes
I understand Haşim brother. Thank you for additional information.
08.05.2020 14:08 # 8
Onur
Thanks for sharing, brother, it works very well
08.05.2020 14:08 # 9
deniz_206
I AM HEALTHY CUBE OF OUR FAMILY OR ITS HEALTH TO THE ABI'S EFFECT.
