Peugeot 307 turn signal lever
08.05.2020 17:01 # 1
mhakan71
As you know, after 307s, the signal lever is on the left, I have been having this problem for a long time, they dismantled the arm, but it was not very healthy. 111; ndiv ">
08.05.2020 17:01 # 2
Best wishes. Scotch Brite method didn't work & nbsp; "LOL"
08.05.2020 17:01 # 3
106fb
[QUOTE = koliva] No good. Scotch Brite method didn't work & nbsp; "LOL" [/ QUOTE]
< div> how was it done? does it work?
08.05.2020 17:01 # 4
[QUOTE = 106fb] [QUOTE = koliva] No good. The Scotch Brite method didn't work & nbsp; "LOL" [/ QUOTE]
< div> how was it done? does it help?
Is it naughty?
http: // forum. peugeotturkey.com/forum_posts.asp?tıd=16786&pıd=261049&title=sinyal-sorunu#261049 Reviews
08.05.2020 17:01 # 5
elsoberano
[QUOTE = koliva] [QUOTE = 106fb] [QUOTE = koliva] No good. The Scotch Brite method didn't work & nbsp; "LOL" [/ QUOTE]
Is it naughty?
http: // forum. peugeotturkey.com/forum_posts.asp?TID=16786&PID=261049&title=sign-sorunu#261049
how to do this I have the same problem.
08.05.2020 17:01 # 6
[QUOTE = elsoberano]
how to do this process I have the same problem
The video in the link is beautifully described. Doesn't the video come out?
08.05.2020 17:01 # 7
mhakan71
friends scoth brite method does not suit us, just add new one to the money:))
08.05.2020 17:01 # 8
maestro
Scotch brayt is used because they chopped money, otherwise banat used :)
08.05.2020 17:01 # 9
[QUOTE = maestro] scotch bray was used because they cut money, otherwise banat used:) [/ QUOTE]
Hahahaha, great or "
08.05.2020 17:01 # 10
elsoberano
[QUOTE = koliva] [QUOTE = elsoberano]
how to do this, I have the same problem
in the link beautifully described in the video. Video does not come out?
[/ QUOTE
& nbsp;
I watched the video.
08.05.2020 17:01 # 11
watched the video telling of trouble & nbsp; no language to understand:) & nbsp;
"Smile"
In the video it says,
We cut out the green part of the Scotch Brite gun. We place the remaining yellow part inside the arm as shown in the video. Nothing else, i'm sorry "Wink"
08.05.2020 17:01 # 12
elsoberano
I watched the video trouble explained & nbsp; no language to understand:) & nbsp;
"Smile"
< / DIV>
my fist I'm trying to get you to remove the plastic under the steering wheel to squeeze the sponge or can it be compressed without disassembling?
08.05.2020 17:01 # 13
my fellow I am trying to deal with it. Should I remove the plastic under the steering wheel to compress the sponge, or can it be compressed without disassembling? [/ QUOTE]
< br> I hope what do you mean? Insertions are not mentioned in the video. He says we're fucking. I think you will just squeeze it in without inserting it. In the video he used Scotch Brite's nail-friendly gun designed for heavy work. He is repainting him "Smile" I think he has a bit harder gun.
08.05.2020 17:01 # 14
elsoberano
thank you very much & nbsp; my fellow & nbsp; my first job & nbsp; getting a scotch brite when you go to the supermarket
08.05.2020 17:01 # 15
kerem
I came here randomly. I have had this problem for a long time, I was accusing myself, I think I am using it badly. I will try the above method at a convenient time. It is not in its normal duration. Why would it do it? Does this method also benefit it?
08.05.2020 17:01 # 16
blinddark
[QUOTE = kerem] I came here randomly :) I have had this problem for a long time, I was accusing myself, I think I am using it badly. I will try the above method in a suitable time.
the signal to the left is fast, not the usual time of day. Why does it do? Does this method benefit it too?
the rear or front signal bulb is likely to explode.
08.05.2020 17:01 # 17
kerem
[QUOTE = blinddark] [QUOTE = kerem] I came here randomly. I have had this problem for a long time, I was accusing myself, I guess I'm using it badly. > It has been giving the signal to the left fast for a few days, not its normal duration. Why does it do this? Does this method also benefit it? / div> [/ QUOTE]
I hope it is from the bulb (good chance) I need to have the electrician look.
08.05.2020 17:01 # 18
DreamTeather
When I tried to give a left signal today, my friends did not give it a few times. According to the head, sometimes it gives a signal, sometimes it does not. When trying between them, headlight, km screen etc. When all the lights turn off, they all turned on. I'm going to change the arm, but the problem with my head is entirely out of the signal arm, or I got a speaker installed today. Is there a wrong connection? & Nbsp;
08.05.2020 17:01 # 19
DreamTeather
date. & nbsp;
08.05.2020 17:01 # 20
DreamTeather
I called the service today. They gave a price of 700 TL to 1000 TL: S So does a signal handle cost so much. There is also a determination about the problem.
When the headlight is on, the headlight goes off and does not turn on when the headlight is off. The signal works normally & nbsp; when the headlight is off (except for its sensitivity). & nbsp;
Page : / 2
