Peugeot 307 Triptonic Gear Error
08.05.2020 16:25 # 1
karakan
My car 2004 model Peugeot 307 XT at 92.000 Km. My car started to give "Automatic Gear Error" error a few months ago. When the vehicle first started, it made a mistake when changing from 1st gear to 2nd gear. There was no problem after the vehicle was stationed and started. When I took it to the service, they said that I had to change the selonoid (electro valve) and transmission oil. We changed the electro valves and oil in a private service that I know and trust. I learned by searching the internet that he did the oil change in accordance with the rules. (The oil level was checked when the gearbox was 80 degrees) When we tested the vehicle, the gear changes were smooth and there was no problem. I used it in the city for a day or two. Then, when I went out of town, after 60-70 km, it again gave an error. This time, Automatic Gear Error did not receive an error message, I just heard the error signal and the "-" sign appeared on the front panel instead of "D" and was showing in snow mode. The gear was still in the wrong position when I hit and run the car. I was getting the same error in triptonic gear. It would improve when I wait 3-4 minutes and run it again. We continued on the road and did not have any trouble while the gear shift up on the road, but whenever the tachometer fell below 2000, it was not shifting down. We slowly came back to Malatya without dropping the age. And when I took it to the master, I missed the gear, he said that the modification is necessary and I waited for the automatic transmission to be opened in Malatya, where I received the information that it will be opened, and I checked it on this day. Although we had a hard time pushing the car, the vehicle did not fail this time. I traveled about 80km for testing purposes. On the slopes, I pushed the car pretty hard, but in general it doesn't make any mistakes. The master said that it was time to regde and he brought me the list that I will write below. Could this failure have happened now because of the cellophonoids I got new? Because I didn't get the same error again. He might have gone to the cellonoids between the master, but this gearbox needs maintenance. What should I do? Shall I give 2.500 TL and wait, or wait for it to fail again? I have already spent around 500 TL on electro valves. 3.000 TL expense makes me feel very good.) It was like an epic. Halal your right.
08.05.2020 16:25 # 2
karakan
In the meantime, I bought my vehicle at 88,000 and had a tube installed. I also use LPG. & Nbsp;
