Peugeot 307 Tailgate Does Not Close |
| 08.05.2020 17:31 | # 1 |
| 08.05.2020 17:31 | # 2 |
mstf shn |
the same problem is the wattage in me is generally more difficult to close in cold weather. Expect help from friends with knowledge ...
| 08.05.2020 17:31 | # 3 |
mstf shn |
I tried to lubricate I did not get any results thanks ...
| 08.05.2020 17:31 | # 4 |
Since the mechanism there is sensitive like a touch, the place pressed becomes deformed over time and the button under it starts not to feel your presses and it does not close when closed. The problem will be solved by cutting out the spring you will remove from the ballpoint pen between the flat surface you touch and disassemble the mechanism.
| 08.05.2020 17:31 | # 5 |
Thank you guys, the lubrication work didn't work, I showed it to the familiar bonnet master, he said the problem was electronic, and the part was a bit expensive.
| 08.05.2020 17:31 | # 6 |
DO NOT TAKE CLEAR PARTS, THE SOLUTION IS LESS FIRST AS EASY AS I AM 5 MINUTES AND A BALLPOINT PEN PRICE.
| 08.05.2020 17:31 | # 7 |
There is a problem in the tongue of the lock on the tailgate. It does not close completely, it opens back as it clicks. Play the tongue with your hand, oil, etc. It is a bit of a mess. The change is not expensive. |
| 08.05.2020 17:31 | # 8 |
Hello friends, I just joined you, luggage problem is chronic
Personally, I unscrewed the lock part of the rear trunk, after removing the two screws, pull the plastic part out and pull it out. Then there are two fingernails holding the mechanism, it is visible on the outer part of the mechanism, push it inwards and remove the socket of the mechanism, friends. ACAN O PLASTIC COMPONENT WITH CONTACTING MECHANISM AND THERE IS A LARGE SIDE THAN 1CM WIDTH, 1CM WIDTH YAY, I would like to be the easiest, no problem. |
| 08.05.2020 17:31 | # 9 |
And if you do not know why you do not close, the friends who open the trunk, the plastic part that we touch loses its feature of being snapped over time, the backlash feature loses its recoil feature, it remains as if it was always pressed and the plastic part touches the sensitive button, it stays as if it is in the open position, it is a problem that I put the bow together, it was a problem, the plastic was the back of the plastic. no contact, no problem disappears |
| 08.05.2020 17:31 | # 10 |
just a bow saves you 250-300tl and takes care of the problem completely regards I hope it was useful |
| 08.05.2020 17:32 | # 11 |
mstf shn |
I will do these operations on a very nice Sunday .... my work will not be wasted. |
| 08.05.2020 17:32 | # 12 |
After you have made sure the application, you will just give me a little bit, but let it not be as small as the inside of the young spicy pen. |
| 08.05.2020 17:32 | # 13 |
When my friend opens the tailgate, there is a little plastic that we touch. When I touch it, the plastic part we touch has a small needle-like part inside it. Especially in the winter, when we hit to close the tailgate, that plastic moves and touches the needle. As such, the tailgate opens again. I pulled the problem out of a bag and rolled it with my hand, then we put it between the plastic and the needle, but not touching the needle. Thus, the part between the plastic and the needle opens and does not touch it when it hits the lid. so the door does not open spontaneously but it opens when we touch the button Also, I want to remind you something specially. After doing these operations, Remember to attach the electric socket. Otherwise, the baggage remains locked. Pay attention to this situation.
| 08.05.2020 17:32 | # 14 |
FRIENDS ARE WE'RE REMOVED AND LOOK AT THE WEEKEND BROUGHT THE BROADCAST IS DEFECTING BE CAREFULL AND BE CAREFUL WHEN YOU REMOVE THE SPRING AND GET GOOD TO TAKE IT FROM THE PARTS
| 08.05.2020 17:32 | # 15 |
Thank you to the friends who commented, I will try your applications immediately
