Peugeot 307 SW Creaking Squeaking Sound Problem
08.05.2020 19:17 # 1
deadlyff
Hello, on the way we will hunt today with the model 307 sw of 2007, because the terrain is rough and the road is broken, forcing the vehicle very hard and tiring 2-3 We had to walk around for hours , the vehicle sank in the mud once during the movement, a few times even though it was not very serious, there were scuffs from the bottom, the vehicle was constantly hurt when we say the right and left pit bump. Later, when it was shaken in the parts of the asphalt road that were damaged on the return road, the squeaking started to come from the car, which I had never encountered before. The squeaks are probably coming from the back of the vehicle, it may be related to the shock absorbers, but I couldn't figure out exactly what happened. What would you suggest me do, could it be a serious problem, if serious, what is it likely to be about? The vehicle I drive is at 40000 km, the maintenance is complete, there are no deficiencies, but for the first time with this vehicle we set off on such a land today. I would be very pleased if friends who have encountered this situation share their experiences. Good forums.
deadlyff 2015-05-20 10:43:50
08.05.2020 19:17 # 2
alilk
Greetings, I have a 2017 307 sw. I bought the vehicle at zero. Since I bought it, a little too much hump or creaking in the ditch has come from behind. As if the bolts loose, the shock absorbers fall empty. I was very inquisitive at first, and it was always the same called `` the sw's are making the shock absorbers so hard ''. I don't know the lies are true, but I got used to this sound. I would be glad if you share your knowledge about this subject.
08.05.2020 19:17 # 3
Faruk
[QUOTE = deadlyff] Hello, with the 2007 model 307 sw going to where we are going to hunt today, because the terrain is rough and the road is damaged, the vehicle is forcing and tiring 2-3 We had to walk around for hours , the vehicle sank in the mud once during the movement, a few times even though it was not very serious, there were scuffs from the bottom, the vehicle was constantly hurt when we say the right and left pit bump. Later, when it was shaken in the parts of the asphalt road that were damaged on the return road, the squeaking started to come from the car, which I had never encountered before. The squeaks are probably coming from the back of the vehicle, it may be related to the shock absorbers, but I couldn't figure out exactly what happened. What would you suggest me do, could it be a serious problem, if serious, what is it likely to be about? The vehicle I drive is at 40000 km, the maintenance is complete, there are no deficiencies, but for the first time with this vehicle we set off on such a land today. I would be very pleased if friends who have encountered this situation share their experiences. Good forums.
Hello, I have the same vehicle.
those sounds come as a squeak in my tiny pit bumps.
if I tighten the rear trunk lock to the same sound once a year since 2010.
To understand whether the sound is from there or not, tap the bottom of the plate, that is, the lock instead of the lock while the boot is closed, and the creaking mixture sounds.
I am still walking in squeaking again, and when I get to the service, I will tighten the place where that luggage lock comes across.
I did not bother myself, but the master firstly removes the metal step at the trunk entrance with that bumper and then tightens the locking mechanism.
Get well soon.
08.05.2020 19:17 # 4
themurat54
Sometimes I like those sounds as if I was using a bus: D
08.05.2020 19:17 # 5
kartalizma
Hi friends, if you say the sound coming from the back comes from the shock absorber, look at the shock absorbers of the vehicle while parking, if there is a material like rubber, if you move it with your hand, you can probably solve the problem with the help of a silicone. Do not move the vehicle for 3-4 hours then use it and that sound will be gone
08.05.2020 19:17 # 6
Adem Kurtuldu
I can not say anything for the back but I guess this is the peugeot chronic problem bnd 2006 206 sometimes I get down and shoot the car comes from the squeak
