Peugeot 307 sw 1.6 pack automatic petrol & lpg
08.05.2020 18:13 # 1
msakraker1912
Friends vehicle 204 model 155.000 and 145.000, heavy maintenance, no change, I am thinking of buying a clean vehicle for 22.000 TL, but I do not have any exact information about the fuel consumption of this vehicle.
08.05.2020 18:13 # 2
barishrocker
I don't know how it is lpg, but it burns very badly on gasoline. They said while I was buying the diesel. You will get less than 25 km and diesel;)
08.05.2020 18:13 # 3
KONYA4285
IF MY FRIEND LEFTS ME, THE PRICE IS SOME HIGH BUT THE FUEL IS ALREADY LPGED, BETTER THAN ONE FOR MORE THAN 350 KRAKS, IT'S BETTER FOR YOU.
08.05.2020 18:13 # 4
msakraker1912
thanks for the answers suggests that it is automatic.
08.05.2020 18:13 # 5
mami202
[QUOTE = msakraker1912] thanks for the answers suggests that it is automatic I have never used an automatic vehicle so far, I do not have full information as a fuel, so I was in the middle [/ QUOTE]
automatic transmission is actually very comfortable and comfortable I will have some humble suggestions for you;
& nbsp; ask the owner of the gearbox if the gearbox oil has changed so far,
While testing the vehicle, you can try the following about the transmission,
start the vehicle & nbsp ; when the handbrake is pulled on, the gear should be in position d and pull your foot from the brake & nbsp; (if the handbrake is applied) the car should push itself forward and even give it in gas slightly, it shows that the gearbox is good if the car moves like paw, & nbsp;
div>
or the simplest way you can try in the & nbsp; bumps & nbsp; front wheels stop without exceeding the bump and start crossing the bump if the vehicle has a hard time to overcome the bump & nbsp; the transmission is troubled if the traction is dropped even though there is power from the engine
< div>
stand on the slope after the vehicle is fully stopped, slowly pull your foot off the brake & nbsp; the transmission must hold the vehicle without rolling back for a while If this is not the case, it is missing directly, even if it continues to kidnap and still doesn & nbsp; after a while, there is a problem, pay attention to the timing of the shifts, especially & nbsp; D - R & nbsp The transitions between; & nbsp; should not be more than 3 seconds.
If you buy the vehicle for long-term healthy operation, it will be very good if you comply with the following,
the gear change before the vehicle stops y & nbsp; P-R_D, especially when the gears between these gears are exactly after the vehicle stops, make the passes. unplug the vehicle after getting on the pads & nbsp; put the gear lever in P mode so that you do not need to put all the load on the vehicle unnecessarily in the gearbox
key, do not know if you have your vehicle), then the gearbox can be confused for some time or esp warning may appear.
& nbsp; finally, it will be better to show the vehicle to a good gearbox master & nbsp; & nbsp; regards with pleasant driving
