Peugeot 307 Stuck in 2nd gear
08.05.2020 19:24 # 1
mrkync
Hello friends. A different error started to occur in my car for a few days. There is no problem in the transition of vehicle gears, but when I try to get rid of the 2nd gear, the gear started to get stuck in between. It is as if there is something in front of the gear. When he pushes, he suddenly passes and does not always do it. Do we have any friends who have trouble like this? Meanwhile, the car's manual gearbox 2005 model peugeot 307 1.6 HDI.
08.05.2020 19:24 # 2
GokhaN
In these and similar situations, the places to look for are certain, usually there may be problems with pressure pads and gear rods.
08.05.2020 19:24 # 3
mrkync
The service had said it was time for the replacement pad to change, but I was expecting that I would manage it a little more. He gave a warning in the car, then the detour appeared to us. Thanks...
08.05.2020 19:24 # 4
serdaralisan
the pressure is not the pad is the problem my friend has other gears going through, there are gear rods and the bottom of the gear drum separator look at it, sometimes it gets stuck as if the knob in the press is holding something in 1 and 2 gear changes
08.05.2020 19:24 # 5
ucanturk
Second gear is going hard in my vehicle. is the solution expensive?
08.05.2020 19:24 # 6
serdaralisan
Shift drum and gear rods create the problem of getting stuck and going hard.
08.05.2020 19:24 # 7
serdaralisan
The last of the gear rods was 30 short, 25 TL gear drum called knob splitter 140 TL last month I asked
