Peugeot 307 stops working for a while
08.05.2020 21:21 # 1
Mertgokce112
Good day I'm new to the forum, I need your help on this.
My vehicle is 2004 model 1.4 HDI. I ran one day, went two meters forward, stopped, worked three or five starts, but after 3 km, it fell off and stopped again and the starter was able to start only after 10 minutes. I barely came back home, the thought of the era was halting. When he did so and worked back, he threw black smoke for a short time, except for black smoke, etc. I do not want to remove injectors because we have no place left because the injector throws white smoke, throws black smoke, or works hard when it is not working for a long time. They said there was dirt in the filter in the tank, we got the tank cleaned and made it look like a little accumulated mud. But the problem still persists. As I was on the straight road, it fell from the circuit a few times as if it was cutting gas. Apart from these, I also get an antipollution fault error when I use too many cycles. We took it to the service, they couldn't find a fault, they said let us look at it one day, but they will get a world money, maybe they will not. I suspect the pump, but they say it is not a pump. Please help
08.05.2020 21:21 # 2
omerb
Did you replace the diesel filter?
08.05.2020 21:21 # 3
Mertgokce112
We replaced the diesel filter with its sensor about a month ago
08.05.2020 21:21 # 4
omerb
If dirt like slime has come out in the fuel tank, it is likely that he will go to the fuel pump.
I think have the pump checked. Disconnect the hose from the pump to the engine. Let's see how the pump pumps the fuel while the pump is running. The problem may be with him.
08.05.2020 21:21 # 5
Mertgokce112
thank you i will check it today i hope it is
08.05.2020 21:21 # 6
omerb
Mr. Mert, do you have any development?
08.05.2020 21:21 # 7
pusutr
It looks like a fuel problem. Is there any leakage or air in the diesel recycling hoses on the engine? I recommend you to have it checked. It is also useful to have the injector washers checked. They do not need to disassemble the injector for this. The problematic injector becomes black around. If there is such a situation, it is useful to replace all injector washers. It's not too costly anyway. But the problem seems to be unable to get the fuel. I hope the diesel filter is original.
08.05.2020 21:21 # 8
Mertgokce112
Service said tomorrow, leave it in the morning. I could not take care of it. There is no master who knows a lot. I don't want to handle everyone here.
08.05.2020 21:21 # 9
Mertgokce112
I hope I will look at all of them tomorrow. Today, I did not have any problems, my car was just too tight once it gave an antipollution error but I did not encounter stopping etc. Thank you I will have it checked
17.08.2021 00:34 # 10
Cyborg2335
Slm, if you found the fault of the vehicle, please reply, I have the same fault in my vehicle, I can't find it.
24.07.2022 02:34 # 11
Erdemcolakk1
Hello Mert,
I had the same problem for 6 months, the masters messed up the car, I took it to the service, now I spent 18 thousand TL, but today the same thing happened again.
25.07.2022 12:15 # 12
Erdemcolakk1
Hello, could you help me solve the problem?
26.07.2022 11:23 # 13
antipollution
Brother, first of all, get well soon. In such cases, first put your vehicle into the computer for 50-100 TL. If I said computer, take a photo of the errors with the error reading device found in the masters from the USB under the steering wheel, which we know. Then you can research these errors for a while and find the source of the problem before handling it to the master. Otherwise, you will lose a lot of money by saying that it is because of this and shaking. Antipolitoun does not give the pollution error only from fuel. It could also be one of the following items. But as I mentioned, first of all, which error codes does your car give, read them from the pc and come here. Antipolution is written on the screen and warns you, but there may be 40 different error numbers in the background. You can get a more accurate orientation from that error number.
  • A malfunction in the ignition coil
  • A malfunction in the spark plug and injectors
  • Occurrence of a malfunction in LPG equipment
  • Clogging in the catalytic converter
  • Oxygen sensor malfunction
  • Bad fuel use
  • Filters are dirty
  • li>
27.07.2022 13:54 # 14
Erdemcolakk1
Hello ,
I couldn't take the car to have the computer checked, it's still at the door, I'm afraid to come to work saying I'll be alone in the morning traffic.
I had an elm327 obd device in my hand, I put it on myself, I checked it on the phone, I don't know how accurate it would be, but I can't take leave from work, I'll take it on the weekend for now.
In the car most of the sensors have been changed, the injection has been revised, the air flow meter has been changed, the radiator has been changed, the timing belt has been changed, one engine and one gearbox in the car have not been touched.
oil maintenance was done 2 weeks ago, last Saturday, we were on the road last Saturday, we were on the road in the evening. (even codes P1666 - P0704- P2800 )
https://drive.google.com/file/d/1lOhmoC4LS5_mafKYioDfNTKBJfv-ulML/view?usp=sharing
Thank you very much for your support and sharing, I'm waiting for your feedback
28.07.2022 08:56 # 15
antipollution
Brother really the first time I've seen different error codes. You have 3 faults with the rocker cover, gear and transmission. The exact result will be obtained when a more advanced device measures it. But at least you need to deal with these issues first instead of going elsewhere.
P1666 iirc is a sync timing error, it could be caused by a faulty cam sensor on the rocker cover.
P0704
CLUTCH SWITCH INPUT CIRCUIT FAULT
Fault code P0704 is related to the clutch switch input circuit. When the driver presses the clutch pedal to change gear, the voltage signal sent from the clutch switch to the PCM drops from high to low.
P2800 Transmission Range Sensor TRS B Circuit Malfunction Transmission Range Sensor B Circuit (PRNDL) Login)
