Peugeot 307 stops when engine starts help
08.05.2020 20:39 # 1
burcues
I wonder why it may be caused by stopping the engine without starting the gas as soon as it starts
08.05.2020 20:39 # 2
[QUOTE = burcues] as soon as you start the engine, it may be caused by stopping without gas. [/ QUOTE]
First of all, welcome to us. If the teacher has LPG in the vehicle, the most likely problem is the gas pump. You should have a test checked for throttle cleaning.
08.05.2020 20:39 # 3
burcues
hb thanks for the answer, i just cleaned the throttle, he said it might be due to him, the master car lpgli but did not look at gasoline still continues the same way
08.05.2020 20:39 # 4
Then my teacher closes the LPG system from the fuse and close the valve of the LPG tank. Use some 100-150 km of gasoline, if the same problems persist, you can concentrate on the gas pump. When you already have a good control, they will look at their values and the pressure may be enough. If the problem is solved in gasoline, there is a problem in the LPG system, it is leaking gas into the combustion chamber, most likely gas cutters and the regulator should be checked.
