Peugeot 307 sound from the back
08.05.2020 16:15 # 1
Lion46
First of all, hello, I would like to consult you how to fix a problem I experienced in my vehicle. I am hearing a strange sound on the right back side of my vehicle for a week. I do not hear this sound on the straight road. It sounds like I can describe it to you as if it was like a bouncer key was put in the empty trunk of the car, it sounds like it bounces when it falls into the pit, but I checked my trunk, there is no possibility to make a sound attached to the spare wheel. the leggings are not idle, I wonder if there is a sound, I looked firmly in place.
08.05.2020 16:15 # 2
metin
could the shock absorber break out? Did you flex the tool with your hand
text 2011-10-17 09:27:30
08.05.2020 16:15 # 3
ginesis80
I have the same problem, did you find a solution? ginesis80 2015-03-07 22:54:53
08.05.2020 16:15 # 4
EmRRmE
Hi everyone,
I just became a new member of the forum.
If the sound you mentioned is a spiritual sound like a iron hitting a iron, the same problem is now I live. It comes from the lining pin of the right rear wheel. I have no problem on smooth roads. I get this sound on cobblestone, stony and rough roads. I don't get the sound when I press the brake.
I wanted to share.
I hope I can help :)
08.05.2020 16:15 # 5
emresensoy307
Well, I showed it to me in the back of the car, I said to the master, the special pejo service said that it would not cut the sound of 10 billion money to the back of this car. I got it to the sound .... it happens when the car is flexing, that is, the lacquer sound was changed when I froze left or passed through the pits ... there is still no sound
08.05.2020 16:15 # 6
EmRRmE
I think the situation there won't go away. The rear has torsion, both the shock absorber and the low limits of the springs will cause us trouble in every bad road condition.
08.05.2020 16:15 # 7
muhammed.ceyhan
The sound you mentioned may come from torsion. I suffer from the same trouble.
08.05.2020 16:15 # 8
swing67
I also have the lacquer, but the sound of the vehicle stretching, the shock absorber chock and the leggings changed again.
08.05.2020 16:15 # 9
EmRRmE
I now have a lacquered sound from the front shock absorbers. Since the car is also a sports spring, yawning is almost too little. Everything is even on the smallest road. It's as good as it is on the transparent side as possible, but with 17 inch 45 sidewall tires, I almost have no comfort. But I'm getting too big in the bends from my car. The effect of torsion is also important here. If I have the opportunity this week, I am thinking of changing all 4 dampers. I will look at the situation after that again.
08.05.2020 16:15 # 10
mcemin
If the damper guards are sticking to the chocks and there are still rattling noises, it is one of the seat belt wraps from the back. The seat belt winding reel in the plastic parts to the right of the trunk makes a sound. Do not change the shock absorber. There are no strong long shock absorbers as much as the 307s. even stretch the rear seat belts and use them. As I said, if you notice that the sound is cut off.
08.05.2020 16:15 # 11
mcemin
and lift the seats in the rear seats by pulling them up front. You will find that the locks of the safety belt buckles are mounted in a tight manner. wrap them with electrical tape. If you want to have a longer life, apply silicone around it. you will eliminate another click source. & nbsp;
08.05.2020 16:15 # 12
mcemin
Also, & nbsp; "Smile"
stick it to the surface where the luggage compartment sits. eliminate a rattling.
08.05.2020 16:15 # 13
swing67
I drew the sponge to the place where the panzot was sitting. I tightened the belts by stretching them to be the sound coming from the reel.
08.05.2020 16:15 # 14
carpediem_ksk
[QUOTE = mcemin] also & nbsp; "Smile"
stick it on the surface where the luggage locker sits. eliminate a rattling too. I would have lowered it if the pendulum was hitting the glass "Smile"
