Peugeot 307 self-lighting
21.12.2022 21:34 # 1
Berkan355252
Hello friends. I have a 2002 model peugeot 307 1.6 xt. After it rained heavily recently, strange problems started to occur in the vehicle. When it is turned off, the headlights on and off, the wiper operation, all the fault lights in the ignition are on. I unplug and plug the battery terminal and start it, there is no problem. Why do you think it might be doing it? What is the solution?
23.12.2022 08:59 # 2
arifbsrn
As far as I've heard, especially in 307s, the bsi brain can absorb water very easily.
youtube Mert Nazmi There is a mechanical engineer's channel called Serin. the videos are a bit long but very informative.
may be fixed with a brain reset or something.
get well soon.
30.12.2022 18:07 # 3
illetyus
There is a water collection reservoir on the lower left side of the windshield
If there is a tube electrical cable or a sound system cable
If it passes, water goes to the brain of the bsi from there.. this is a liquid gasket
Al and close the hole there .. I had the same problem with imbo
We were able to start the car by canceling it.. and I couldn't find the BSI brain even in Izmir
Air conditioner doesn't work when imbo is cancelled.. < /div>
