Peugeot 307 Remote Control Not Working
17.05.2021 15:53 # 1
MustafaT
I bought my car 4 5 months ago and when I bought it, the remote control was not working. I showed it to some masters in Hatay and Osmaniye, they said that the service sends the electrician to the electrician and the original remote control cannot be saved. Is there anything I can do about it? Or can you recommend a master who can do this in Hatay, Osmaniye and Adana?
19.05.2021 23:54 # 2
talip206
I think it will work if you find a second hand original key and code it into your car's brain. Makes a good switcher.
11.06.2021 15:26 # 3
Selim307
Plug the chip in the key body into another key case and try with compatible ones.
22.02.2022 21:45 # 4
egeca77
Turn the ignition once, with the key inserted, press the unlock button on the key a few times, then turn off the ignition and the remote control will work. If not, try a few more times. I had the same problem, and it was fixed with this method.
