Peugeot 307 "-" Snow and Sports Mode Lights
11.01.2022 00:19 # 1
qala
Hello. I have a Peugeot 307 1.6 XT automatic transmission vehicle. As I mentioned in the title 1 week ago, "-" (dash-line) snow and sport mode lights are on on the screen where the gear indicator is. it knocks and the last time it hits very hard, these lights start to come on.
When I stop and start the vehicle, the lights continue to come on and the vehicle's traction decreases. After 5-10 minutes of moving like that, the vehicle returns to normal and the gears etc. there is no knocking. In addition, the vehicle did not fail that day again.
First, I took the vehicle to the authorized Peugeot service. They said there would be a transmission change directly and they said they would bring it from abroad and asked for a large amount of money (Almost close to the vehicle money).
I took the vehicle from the service to the automatic transmission shop. There, they said that the car was used with lpg constantly before, and because I had been using petrol for about 2 months, the petrol and lpg brains of the vehicle were confused. They said keep using it like this, it will pass soon.
I talked to another transmission man on the phone just to be sure. That master said that this error could not be related to him.
The errors given by the vehicle are as follows:
- Engine communication error with gearbox | Intermittent Error
- Sequential solenoid valve 1 output error open circuit | Persistent Error
< div>
Although it gives a solenoid valve error, I have never heard a sentence about solenoid from the mouth of any master. I live in Ankara. Is there a master you can recommend? Or anyone who knows about the error?
11.01.2022 11:40 # 2
Hello teacher. As the problem appears, if there is no fault from the solenoid valves anyway, why would it give an error? Unfortunately, there is no one who does not experience this problem in the first versions of all4 gearboxes. but there is a short circuit in the transmission brain of the vehicle, probably either in the cables or in the brain sockets, of course, it is difficult to find a master. Unfortunately. now they will probably make a complete revision conversation, and some will give it a price between 10000-15000 TL.
and if you want, I would like to talk to you here.
11.01.2022 18:19 # 3
qala
As you said yes, they all say revision. So, do you have any information about this gasoline, LPG brain mixing thing? Is such a thing possible? I'm asking because I don't know much about cars.
12.01.2022 10:32 # 4
It is irrelevant, sir, the lpg brain is a different independent system. The engine brain of the vehicle is different, it works according to gasoline. However, the vehicle that does not run properly on gasoline is not expected to work properly on LPG, the reason is that the LPG settings are made according to the gasoline values of the vehicle and the LPG ECU (registered to the brain.) LPG injectors work accordingly. Of course, if the engine ecu (brain) is faulty, there may be situations that affect the LPG system.
