Peugeot 307 power steering pump failure
15.06.2023 16:10 # 1
Black label
Hello friends, I have a Peugeot 307 1.6 gasoline / LPG vehicle. We had a problem with the power steering pump. We replaced the pump we had previously had problems with with a used original. Water had gotten into the card slot that came out of it. We found the original and replaced it. It was used for about 6 months, but now the pump we installed doesn't work when I start the car. It works and works when the car moves a little. It works fine on the road. However, it doesn't work when I stop and start it again. I have to move the car a little for it to work. The battery is new, bought new, only 2 months old, 74 amp. The fuse box was checked, but there's no problem. The alternator is functioning properly, the pump sockets are clean, and the wiring is also fine. We couldn't solve the problem. Has anyone experienced this before?! How did they find a solution?! Does anyone have any ideas? Black label2023-06-15 17:10:53
19.06.2023 00:43 # 2
Yasincelik1987
I had similar problems, even during sudden maneuvers the steering wheel seemed to be stiff and was turning with difficulty. We solved the problem by adding steering hydraulics.
20.11.2023 22:41 # 3
black_jeruz
[QUOTE=Yasincelik1987]I had similar problems, even during sudden manoeuvres the steering wheel seemed to be stiff and it was difficult to turn. We solved the problem by adding steering fluid[/QUOTE] Hello Yasin, good evening. I also have a 307 1.6 petrol XT model. The steering wheel gets stuck especially in cold weather. For example, when turning left, the steering wheel reacts as if it is turning right. After the engine warms up, there is no problem. It does this especially in cold weather. I have no problems in warm weather. The vehicle is leaking oil from the steering pump and the cable connections are always in oil. Could it be that the chassis is making it? My steering box started to have these problems after it was overhauled. Also, the oil is jet black. Where did you have it done? I am replacing it in Istanbul. I would appreciate it if you could write an answer... black_jeruz2023-11-20 22:42:19
25.11.2025 15:41 # 4
heffera
Did you find the answer to your problem?
25.11.2025 15:42 # 5
heffera
[QUOTE=black_jeruz][QUOTE=Yasincelik1987]I had similar problems, even during sudden manoeuvres the steering wheel seemed to be stiff and it was difficult to turn. We solved the problem by adding steering fluid[/QUOTE] Hello Yasin, good evening. I also have a 307 1.6 petrol xt model car. The steering wheel gets stuck especially in cold weather. For example, when turning left, the steering wheel reacts as if it is turning right. After the engine warms up, there is no problem. It does this especially in cold weather. I have no problems in warm weather. The vehicle is leaking oil from the steering pump and the cable connections are always in oil. Could it be that the chassis is making it? My steering box started to have these problems after it was overhauled. Also, the oil is jet black. Where did you have it done? I have a replacement in Istanbul. I would appreciate it if you could write an answer... [/QUOTE] How did you solve the problem? I have the same problem.
