Peugeot 307 petrol gauge
08.05.2020 17:52 # 1
dream
As you know, the 2006 model Peugeot 1.6 XT BVA gasoline vehicle was recently applied to the LPG obd system.
Now, while this system is working with LPG, it detects as if it is burning gasoline and lowers the petrol indicator.
Currently, my vehicle has more than half a tank, but the indicator warns.
When I go and buy 20-25 pounds of gas, the indicator becomes half a tank again.
But my main question is this; If I continue to travel even though I know that my vehicle you give warning is half a tank or more petrol, will I harm my vehicle?
I have a friend who said the gas pump would be damaged, do I have a copy?
08.05.2020 17:52 # 2
impact
You don't harm the vehicle, brother.
however, since the gas pump continues to run, it might be a nuisance in the long run.
I made about 5 thousand km and we did around 50 thousand with vectra.
08.05.2020 17:52 # 3
EnSoNiQ
I do not know if it is suitable for the system you have installed, but there is a module called psa module. They told me how to install it in the link below.
Meanwhile, the fuel pump does not work when it passes to the tube because it does not have to prevent the gas pump from the car, otherwise the car runs with both gasoline and tube, which causes the vehicle to faint: D
ENSONIQ 2013-08-14 14:52:40
08.05.2020 17:52 # 4
impact
I do not know if [QUOTE = EnSoNiQ] teacher is suitable for the system you have installed but there is a module called psa module.
I just heard it cut off from the injectors (except for a few LPG brands) I know that the gas pump is working.
