Peugeot 307 Pedal Group
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 14:08 # 1
hasimayaz
1 - PEDAL GROUP (LEFT STEERING)
The pedal group includes the brake and clutch pedals.
This pedal group is fixed by pressing the front chest sheet (1) (2) through the studs (3) connected to the braking amplifier.
The accelerator pedal is fixed on the axle (4) on the tunnel.
2 - PEDAL GROUP (SAUGH STRAIGHT)
The pedal group includes clutch pedals, brake and accelerator pedals.
The tandem master cylinder and brake amplifier are located on the left side; a rod allows the drive force to be transmitted to the tandem main cylinder.
3 - PEDAL GROUP (DRIVER SCHOOL)
The pedal group of the driving school vehicle has the principle of right and left-hand drive pedal group; the rods allow the driving coach's movements to be transmitted to the other side.
The driving instructor's clutch pedal is separate from the novice driver's pedal; pedal reinforcement is mounted on the novice driver's side.
Brake pedals on the driver's side and novice driver's side are double.
Pedal on the side of the driving instructor; :
  • It can be disassembled and mounted thanks to a (6) diagram that allows the pedal to be fixed without being visible under the instrument panel.
  • Thanks to one (7) clip the pair can be used with the accelerator pedal on the beginner driver
The pedals used by the driver of the school can be adjusted in height.
