Peugeot 307 parking sensor not working
08.05.2020 20:38 # 1
ben_erhan
The parking sensor of my 2004 model 1.6 gasoline automatic car has been problematic for 1 month .. one morning when I put the parking sensor in reverse, it made a long dittt sound and stopped working. the sensors are not reading .. I searched in the forum, I said from the customer, I do not think that the back light will be on the customer. I know the task of the customer is to send the electricity to the lamp .. eyes or malfunction, water entered the brain or lph tank made moisture in the brain. I couldn't understand .. what did those who experienced and solved this problem do?
08.05.2020 20:38 # 2
One of the eyes is broken or water has gone into its sockets, oxidation may cause this problem. I guess your parking sensor brain was in the left rear fender.
08.05.2020 20:38 # 3
ben_erhan
Today I will try to disassemble the sensors and the brain.
Since it is after installing a bagel tank, I will look at the brain first, maybe it may have made moisture.
08.05.2020 20:38 # 4
KILIC
He probably made oxidation. I hope you can easily handle it.
08.05.2020 20:38 # 5
In this, my teacher gets oil-free contact spray and clean the sockets. This spray has the feature of preventing short circuit because it prevents both cleaning, moistening and oxidation.
08.05.2020 20:38 # 6
oldjack
Master, Removed glass, athermic glass can be green, had it happened to me before? If you ask a service, is the original glass glass Athermic?
08.05.2020 20:38 # 7
ben_erhan
When the car pulls under the sun, it heals for half an hour .. No problem until it rains again .. When the rain falls, the problem arises again. It takes water from somewhere but I couldn't find where. You will call it the brain. The brain is dry ... something like that is not even attempted. The cables of the sensors are not removed and the experiment is not done. This time, the cable has been removed. At least if I find out which sensor is wrong, I just focus on it ... there is a lot of room to check in this way ..
08.05.2020 20:38 # 8
I would like to try and get one zero on my teacher aliex. cheap in prices
08.05.2020 20:38 # 9
nbol
[QUOTE = ben_erhan] When I pull the car under the sun, it heals for half an hour. I want to change it because it is .. it takes water from somewhere but I couldn't find where. You will call it the brain. The brain is dry ... something like that is not even attempted. The cables of the sensors are not removed and the experiment is not done. This time, the cable has been removed. If at least which sensor turned out to be a problem, I would just focus on it ... there are so many places I should check this way .. [/ QUOTE]
Sir, where exactly is the parking sensor brain? My sensors were also unable to locate the defective brain. Is it necessary to remove the bumper to reach the brain?
08.05.2020 20:38 # 10
ben_erhan
[QUOTE = nbol] [QUOTE = ben_erhan] It heals half an hour when I pull the car under the sun. It has not improved .. I do not want to change it because the system is solid .. it takes water from somewhere but I could not find where. You will call it the brain. The brain is dry ... something like that is not even attempted. The cables of the sensors are not removed and the experiment is not done. This time, the cable has been removed. If at least which sensor turned out to be a problem, I would just focus on it ... there are so many places I should check this way .. [/ QUOTE]
You remove the plastic that protects the luggage lock.
08.05.2020 20:38 # 11
ben_erhan
[QUOTE = sonerkyl] My teacher, I would like to try and get one zero on aliex. cheap in prices
Soner brother is the number 9646244777 on the sensor in me, but I have never found it with this code on aliexpress.It's only here .. If the 307 sensors in express fit the sensors, I will never look at it ... do you know if it will fit or not?
08.05.2020 20:38 # 12
[QUOTE = ben_erhan] [QUOTE = sonerkyl] My teacher, I say, try to get one zero on aliex. cheap in prices
Soner brother is the number 9646244777 on the sensor in me, but I have never found it with this code on aliexpress. It's just here.
https://tr.aliexpress.com/item/otomobil-4-park-mesafe-kontrol-sens-r-pdc-9646244777-peugeot-307-i-in-g-venlik-alarm/32840591172.html
I hope it works for you, teacher Smile
08.05.2020 20:38 # 13
ben_erhan
[QUOTE = sonerkyl] [QUOTE = ben_erhan] [QUOTE = sonerkyl] I would like to try and get one zero in aliex. cheap in prices
It was the only product I could find, but it was out of sale ..
I called the service, they looked with the chassis number. He said the code number 6590.01 ... there is a fear of warning if I get it. The sensors in me are brand of valeo .. the service is not original, says .. we do not have such a code, he said. The price of 6590.01 you need to buy is one eye 360tl. :)
08.05.2020 20:38 # 14
ben_erhan
Made in China, the sensor eye has come.
but it is not working properly .. it does not sound anymore .. the only thing it does is not in failure is now .. the system is active ..
Apart from that, there is no efficiency .. I will try to disassemble it and change its direction ...
08.05.2020 20:38 # 15
[QUOTE = ben_erhan] made in china sensor eye came on ..
strange erhan hocam, I have never heard of those who buy and install sensors from china. Replace another sensors as your grandfather.
