peugeot 307 original tape replacement
08.05.2020 16:36 # 1
salihata
friends, I have 2003 model 307 vehicle, I can not get the efficiency from the original tape I want to ask, I do not know that I am not a person who likes to listen to very loud music. Do I need to change it? I think the tape 2350ub pioneer? can you help me?
08.05.2020 16:36 # 2
Cmoss06
The tape in your vehicle is not a poor quality tape, the columns are insufficient. "smileys / smiley36.gif" height = "17" width = "17" border = "0" alt = "LOL" title = "LOL" />
08.05.2020 16:36 # 3
Cmoss06
If you plug in the Ponyone tape without replacing the speakers, you will not get any results.
08.05.2020 16:36 # 4
erkerd5429
I had the same problem, I bought a tape with usb / sd card reader. It was 85 lira.
08.05.2020 16:36 # 5
salihata
Actually, I will change the tape anyway because I don't have a CD player, I listen to mp 3s with tape adapter & nbsp; "Big & nbsp; eee well Is there any column you can recommend to this tape, I'm foreign? & nbsp; "Smile" & nbsp;
08.05.2020 16:36 # 6
Cmoss06
My brother has the material according to your money. Its prediction is a normal level & nbsp; tape + speakers find around 400 TL.
08.05.2020 16:36 # 7
Alicilik
[QUOTE = Cmoss06] The tape in your car is not a poor quality tape, the columns are inadequate. You will see a change in the front and rear of the speaker set. change "LOL" [/ QUOTE]
Original I think the tape is RD3 and the outputs are not even 40w.
I speak for my own vehicle;
Factory outlet RD3 had a cd player. Normal coax in front. There were 165mm. Its brand does not print fln.
I replaced the front speaker. With Pioneer one-way 16cm. The sound has changed. Since there is no installation on the back doors, I made Mdf sponge and put the Pioneer oval. When he louder, he started to choke.
I bought the Pioneer deh-2300UB and changed it directly, cable etc. no problem, I did it myself. The change in sound was seriously satisfying.
Now I am using Deh 9350 xetec I have 5 channel amps in front of them. I am feeding the kicker ds 650.2 in front of them. I have done everything myself again in the installation.
Tape change will change things. But if the speaker is changed and amphitheater is used according to the possibility, then it is not eaten. Even though the sound level is up to 62, I can't stay in the car in the 30s. Even in the 50s, very clear treble sounds.
08.05.2020 16:36 # 8
Cmoss06
I guess you haven't read the subject and didn't mention the high performance sound
08.05.2020 16:36 # 9
Alicilik
[QUOTE = Cmoss06] I haven't read the subject, I guess he didn't mention the high performance sound [/ QUOTE]
I also mentioned my changes.
Pioneer, Alpine, Sony, Clarion production, even with a lower level, makes a difference with a tape. The speakers may remain if they are not too old.
It can be adapted to the Wired remote input of these devices in the control arm.
RD3 tape is distorted after 25/32, but even in pioneer 45/62, you get almost 1.5 times of that sound and there is no defect. If you go over 45 and the eq is not set, the sound is a headache.
08.05.2020 16:36 # 10
Cmoss06
Correctly, of course, the pioneer and the clarion are different one 4x50 and the other 4x15 difference should be this. Rd3's & nbsp; max sound level is 30 times in the pioneer, even three times the HPs in peutos are good as cones but magnet weak mid and treble sounds but bass are very bad.
& nbsp;
Meanwhile, according to the set, & nbsp; use goodbye "Clap Vehicle 206+ I guess God shouldn't cause trouble.
08.05.2020 16:36 # 11
Alicilik
[QUOTE = Cmoss06] [QUOTE] You must be right, of course, it must already be different from the pioneer 4x50 the other 4x15 difference This should be the rd3's & nbsp; max sound level 30 pioneer two or even three times the peugeot hps are good as cone but magnet weak mid and treble sounds but the bass are very bad. [/ QUOTE]
The hp that I removed from the car gave good sound at high frequencies. Pioneer felt the bass a little more. The ovals were already moving the back. But here is the human son does not know how to settle & nbsp; "LOL"
& nbsp; [QUOTE]
< br>
By the way, according to what the set says & nbsp; use goodbye bye "Clap" Vehicle 206+ I guess God shouldn't be in trouble.
Thank you for your good wishes. May Allah not cause any trouble to our sentence. I have a sound system for hand labor. I bought the parts and pulled the whole installation myself. I will start the insulation business soon. If there is time left from school and work, I am interested in my car. We would love to see you too.
ScHerZo 2012-02-23 15:47:24
08.05.2020 16:36 # 12
istanbullu_3886
I do not change the original tape, because when it connects the car to the computer, it establishes the communication over the original tejib, buy an original CD player, plug it in, or there are card usb readers set up on that tape.
08.05.2020 16:36 # 13
Alicilik
[QUOTE = istanbullu_3886] I do not change the original tape, because when you connect the car to the computer, it establishes the communication over the original tejib, buy an original cd player, plug it in, or there are usb card readers set up on that tape. br>
Is this incident valid for every vehicle?
There are no 307 owners in my environment who use the original tape because there was no problem in the service. We mounted the tape in the glove box and it is using it very stable. Reviews
08.05.2020 16:36 # 14
Cmoss06
I hope it is "LOL"
08.05.2020 16:36 # 15
Cmoss06
I use my cd player to keep my secret in mind.
08.05.2020 16:36 # 16
Alicilik
[QUOTE = Cmoss06] I use cd player to keep my secret invisible. "Cry" /> [/ QUOTE]
I had a single line, and I changed the system when it was there. Then I inserted 3 lines and the screen was blank. I wore the original tape sometime, the middle screen was great, I liked it, but there was no sound quality. For a while I thought I would put the pioneer in the glove box, but then I said no need. It is enough to see the degree and trip computer that is important. I see them too.
08.05.2020 16:36 # 17
Cmoss06
When I was one line, I did not wear it, but when I put it in 3 lines, I put it back on it, as I said, the screen is festive, but I need to do something
08.05.2020 16:36 # 18
salihata
If I insert a cassette to the original confirmation, maybe I can really get the exact efficiency I want =) but I bought a cassette adapter, I attach it to the mp3 player on the end of it, I don't like the music to be listened. If I put in the original tape before connecting it to the computer before I take it, if I use the tape that I bought later on? I'm really foreign to this car business =)
08.05.2020 16:36 # 19
Cmoss06
As far as I know, the original parking sensor tape system is likely to have some data transitions over the tape, but I am not sure, I have to ask friends who are not sure
08.05.2020 16:36 # 20
istanbullu_3886
[QUOTE = ScHerZo] [QUOTE = istanbullu_3886] I do not change the original tape because when it connects the computer to the computer, it establishes the communication over the original tejib, get an original cd player, plug it in, or there are USB card readers set up on that tape, I took it from them, but they do not sound well. [/ QUOTE]
There are no 307 owners using the original tape around me because the service has not been a problem either. Because it is attached, the tape has not changed and we mounted the tape in the glove box and it is using it very stable.
[/ QUOTE] my master told me a lot about this subject I understood with the technical term it should be just original
Page : / 2
