Peugeot 307 Multimedia Ignition does not turn off when turned off
08.05.2020 19:15 # 1
gkhn92
Hello everyone
2004 I bought Navimex multimedia for my model Peugeot 307 1.6 XT. It works just fine, but there is a minor problem. I stop the car, lock and go, the multimedia remains open for 3-4 more minutes. I made all the settings but it doesn't improve. What should I do, how do I fix it. Thank you from now.
08.05.2020 19:15 # 2
ErcanK.
Hello there,
I got 307 me jamesson JS-96. 2 minutes after switching off the ignition. then it shuts down. They stated that they could not do anything to lower the place where I had it. I hope you find a solution.
08.05.2020 19:15 # 3
gkhn92
Are you having a battery problem? How long has it been tactic?
08.05.2020 19:15 # 4
TugyyStyle
It is normal to stay open for 3 - 4 minutes :) if it turns off then it's ok :)
08.05.2020 19:15 # 5
ErcanK.
ercann. 2016-02-08 12:39:01
08.05.2020 19:15 # 6
Viruse
My friend is the only solution to what you want to do in connection cables. I have the Pioneer X7500BT In Dash. I lock the vehicle. After 2 minutes, the power cuts off and pulls the screen in. Disconnecting power is related to Peugeot. I think friends who connect do not know the Peugeot infrastructure and cable layout. Well, I am extremely pleased.
08.05.2020 19:15 # 7
gkhn92
It is already closing 2 minutes later, I want it to close as soon as I switch off the contact.
08.05.2020 19:15 # 8
Viruse
It may be what you want, but since some devices do not have high voltage Protection, Peugeots give Current after the ignition is turned on so that the device will not be damaged when it turns the first contact. Still, you have to ask the knower.
08.05.2020 19:15 # 9
gkhn92
Does it cause a different problem if I get the electricity from the contact? I'm not comfortable, I leave the car like this and I feel like it will never close :)
08.05.2020 19:15 # 10
Alicilik
No need to contact either.
There is a bowl in the corner of the socket. The trigger below the memory feed next to it is connected to them.
3 cables have 1 fixed and 2 combinations, they can connect it incorrectly. Don't bring the car to these guys.
08.05.2020 19:15 # 11
gkhn92
How can I not understand exactly, can you explain more?
08.05.2020 19:15 # 12
ucanturk
this is one of my favorite features. I do not try to close it when I get off, and when I open the doors, multimedia opens spontaneously.
08.05.2020 19:15 # 13
Oguzhn
When the cables from the original tape are not the socket with the audio cables but the socket with the power cables, the 2nd cable from the left should be green. that cable is connected to the contact, that is, the power comes when the contact is opened. If you take the tape power from there, you will reach the solution you want. but if it did not cause any problems in the battery, I don't need to mix it.
08.05.2020 19:15 # 14
red 206
friends, easy to come, the event you mentioned happened to me. There are connection diagrams of the cables. There are 2 + 12 V cables on this socket (standard on each vehicle). One of these cables is for tape feeding, the other is the tape without opening the contact when you connect it to the start end of the tape. As soon as I understand that, when the ignition is turned off, the top energy is cut off immediately, as I understand, your tapes are feeding their energy from the same place with the peugeot km indicator (as I said, find the two ends properly and your problem will be solved when you make the right connections (nothing is impossible.
